DACH Supersonic November 12, 2018 Share November 12, 2018 https://www.carsguide.com.au/car-news/mitsubishi-triton-2019-revealed-71824 Mitsubishi has ripped the covers from its facelifted Triton that is set to hit Australian showrooms in January 2019, with the updated pick-up ushering in a fresh front-end design, more active safety features and a new six-speed automatic transmission. The biggest change for the updated Triton is the new ‘Dynamic Shield’ front fascia that incorporates higher-set slimline headlights, a revised lower bumper, more sculpted bonnet and an updated grille with chrome flourishes. This design theme is found on most of Mitsubishi’s SUV models including the ASX, Eclipse Cross, Outlander and the related Pajero Sport. Mitsubishi says the front end “uses a horizontal/vertical motif and beefier chrome parts to give a sense of powerful rigidity in a design that echoes the ‘Engineered beyond Tough’ development concept.” Australian pricing and specification are still yet to be announced, but higher-spec variants gain bi-functional LED headlights, and the foglights have also been raised to protect the lighting elements from stone chips and high-water crossings, according to Mitsubishi. The rear bumper has been streamlined and is now integrated into the bodywork, and the bed sides and tail-lights have been restyled. There are fewer changes inside the new Triton, but it gains silver detailing and soft-touch materials. It also features a double-stitched finish on the front seat armrest, knee pads, console lid, brake lever and shifter. The door trims are now slightly thicker than the outgoing model. Second-row occupants now have access to a USB outlet and a roof-mounted air vent with four levels of airflow adjustment, while trays have been fitted around the centre console for smartphone or tablet stowage. Mitsubishi has increased the Thai-built Triton’s rigidity and added more sound-proofing and noise- and vibration-absorbing materials to improve cabin noise levels. The Japanese carmaker has increased available safety systems, which includes the addition of a camera- and radar-based front collision mitigation system with pedestrian detection, blind-spot monitoring with lane-change assist, rear cross-traffic alert and ‘Ultrasonic Misacceleration Mitigation’ that helps prevent unintended motion. A surround-view 'Multi-Around Monitor' will be offered as an option, at least in some international markets, while front and rear parking sensors will be offered and a reversing camera will carry over. Mitsubishi’s on-the-fly 'Easy Select' 4WD system with four modes including rear-drive, four-wheel-drive, and high- and low-range 4WD will also carry over from the previous model. When switched to all-wheel drive mode, the Triton now features an 'Off-Road Mode' that allows specific terrain selection between Gravel, Mud/Snow, Sand and Rock settings for improved control. The Triton is now fitted with hill descent control which operates at speeds up to 20km/h in 4WD modes. The suspension system mostly carries over, namely a double wishbone front and leaf spring rear set-up, but Mitsubishi says it has tweaked it to improve comfort, largely due to to bigger rear dampers. On overseas models fitted with 18-inch wheels, the brakes have been upgraded and now use larger ventilated discs with two-piston calipers. Powered by the carryover 2.4-litre turbo-diesel engine, the new Triton produces its peak 133kW of power at 3500rpm and maximum 430Nm of torque from 2500rpm. A 2.4-litrepetrol engine is still available. While the facelifted Triton is offered with a carryover six-speed manual and five-speed automatic transmission, a new six-ratio self-shifter with a Sport mode will also be offered in the new version. The new Triton is offered in four new colours – 'White Diamond', 'Graphite Grey', 'Passion Orange' and red – while white, 'Silver Metallic', 'Black Mica', 'Blue Metallic' and 'Brown Metallic' carry over. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 13, 2018 Share November 13, 2018 @jman888 can change the topic to “5th Gen Mitsubishi Triton Facelift .......” https://paultan.org/2018/11/09/2019-mitsubishi-triton-facelift-debuts-in-thailand/ 2 Link to post Share on other sites More sharing options...
13177 Hypersonic November 13, 2018 Share November 13, 2018 Is bro Mustank getting this? 1 Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged November 13, 2018 Share November 13, 2018 @mustank 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic November 13, 2018 Share November 13, 2018 No no No money Car is not important to me Can move can already Anyway I saw the ford pickup Very macho very man 2 Link to post Share on other sites More sharing options...
Friendstar Supercharged November 13, 2018 Share November 13, 2018 @mustank the great Link to post Share on other sites More sharing options...
Mustank Hypersonic November 13, 2018 Share November 13, 2018 @mustank the greatSimi greatI ish a small man Just trying to earn a living Make do make do abit in life Most people is like that anyway Car can move, can already lah, ask for much, also give much Link to post Share on other sites More sharing options...
13177 Hypersonic November 13, 2018 Share November 13, 2018 No no No money Car is not important to me Can move can already Anyway I saw the ford pickup Very macho very man Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 13, 2018 Share November 13, 2018 No no No money Car is not important to me Can move can already Anyway I saw the ford pickup Very macho very man For youhttps://paultan.org/2018/10/26/2019-ford-ranger-line-up-in-malaysia-spec-by-spec-compared/ Link to post Share on other sites More sharing options...
Mustank Hypersonic November 13, 2018 Share November 13, 2018 For you https://paultan.org/2018/10/26/2019-ford-ranger-line-up-in-malaysia-spec-by-spec-compared/ Wah! This guy really into it!! Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 13, 2018 Share November 13, 2018 Wah! This guy really into it!! 4th gen Triton Link to post Share on other sites More sharing options...
DACH Supersonic November 13, 2018 Author Share November 13, 2018 Simi great I ish a small man Just trying to earn a living Make do make do abit in life Most people is like that anyway Car can move, can already lah, ask for much, also give much Less talk. Wait for you to buy and show us here. Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 22, 2018 Share November 22, 2018 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 27, 2018 Share December 27, 2018 Pickup drag race ↡ Advertisement Link to post Share on other sites More sharing options...
2019 2nd Generation Audi Q3
2019 All new Mazda 3
2018 / 2019 7th Generation Lexus ES
2020 Mitsubishi Attrage (Part 2)
