Jj5599 1st Gear August 21, 2010 Share August 21, 2010 (edited) Hi, can anyone please help me with how much pressure to pump for my front and for my rear tyres? I can't understand the typre pressure label in the photo. thanks! Edited August 21, 2010 by Jj5599 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
SimonTan 2nd Gear August 21, 2010 Share August 21, 2010 BMW....what a nice car. 1 Link to post Share on other sites More sharing options...
5936 1st Gear August 21, 2010 Share August 21, 2010 Lots of figures, but not too difficult. 1) Look for your tyre size 2) Decide on load 4 pax or full load with lagguages 3) Cross check column on pressures for front and rear tyres. From my experience, the normal 4 pax us good enough for every day use. I like this type of chart. I had one that's even more headache-- 3 levels of press. 2 front pax. 4 Pax 4 Pax & lagguages. MIC & MIK cars same press from all tyres. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 21, 2010 Share August 21, 2010 What is your tyre size? And how many people do you usually carry? 1 Link to post Share on other sites More sharing options...
Opel17 6th Gear August 21, 2010 Share August 21, 2010 If the nos 5 passenger is someone you dun like, you can explain that the tire pressure chart allow only 4 pax maximum, please call a cab yourself. 3 Link to post Share on other sites More sharing options...
Jj5599 1st Gear August 21, 2010 Author Share August 21, 2010 4 passengers. Tyre size I don't know, should be default. Link to post Share on other sites More sharing options...
Civic93porsche911 Neutral Newbie August 21, 2010 Share August 21, 2010 29psi front 32psi back 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 21, 2010 Share August 21, 2010 4 passengers. Tyre size I don't know, should be default. You should read yr tyre size off your default tyre then let us know. Then we can help you on the correct pressure to pump. 1 Link to post Share on other sites More sharing options...
Jj5599 1st Gear August 22, 2010 Author Share August 22, 2010 Tyre size is 205/55 R 16 91W Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 22, 2010 Share August 22, 2010 (edited) Then should be front 2.0 bar and rear 2.2 bar. Use this website for conversion: http://www.tvr-webmart.co.uk/tvr_info_psi.asp Edited August 22, 2010 by Fcw75 Link to post Share on other sites More sharing options...
Jj5599 1st Gear August 22, 2010 Author Share August 22, 2010 thanks! Link to post Share on other sites More sharing options...
Camrysfa Turbocharged August 6, 2016 Share August 6, 2016 When is getting a nail/screw poked into the tyre considered too often? Yesterday I had the 2nd in 6months ( too often ). As the tyres were already 3 years old, had them changed and had 2 surprises: - the tyre shop pump to 140KPa(34PSI) while I had been only letting in 215KPa(31PSI). - the mechanic checked the front tyres and found one with 300KPa ( wow, how did this happen when I usually select 215 at the air pump ) tyre size is 195/65/R15 2 Link to post Share on other sites More sharing options...
Soya Supersonic August 6, 2016 Share August 6, 2016 Could be a leaky valve stem. Or tyre guy anyhow pump. Seem to hv this issue everytime they helpfully "check" & rotate my tyres. Always end up having to recalibrate the pressures myself after that. 2 Link to post Share on other sites More sharing options...
izzy0707 Neutral Newbie August 20, 2018 Share August 20, 2018 Guys, im driving suzuki swift sport zc31. I followed the tyre pressure and pump til 330 kpa. Is it okay or too much? 2 Link to post Share on other sites More sharing options...
DACH Supersonic August 20, 2018 Share August 20, 2018 330kpa is too much. I think 220-240 is enough for your car. Link to post Share on other sites More sharing options...
izzy0707 Neutral Newbie August 21, 2018 Share August 21, 2018 Cause i cant find the tyre placard on my right side of my driver door. So anyone know the recommended tyre pressure? 240? Link to post Share on other sites More sharing options...
Cheesey74 6th Gear August 21, 2018 Share August 21, 2018 For swift, i would think 220kPa should be the norm n 240kPa for a firm ride. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic August 21, 2018 Share August 21, 2018 This kinda thing can easily Google. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Tourador Tyres
Tourador Tyres
Tyre puncture
Tyre puncture
Replacing a 2yrs old tyre?
Yokohama Advan Apex V601
