Saabest 2nd Gear February 1, 2009 Share February 1, 2009 Anyone can share with me where I can get on-car high speed wheel balancing done and at what cost? Preferably around Bukit Batok, Clementi or Bukit Panjang area? My steering tends to vibrate when driving at speeds above 100km/hr; I believe this would solve the problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Weihui Clutched February 1, 2009 Share February 1, 2009 Can try Autobacs Bukit Batok. I recalled seeing the service listed on their menu. Link to post Share on other sites More sharing options...
Sparks Neutral Newbie February 1, 2009 Share February 1, 2009 Err, hi there, wrong thread you have posted in. I reckon this is more suitable under the Tyres and Rims section, you could find your answer there too. Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie February 1, 2009 Share February 1, 2009 Anyone can share with me where I can get on-car high speed wheel balancing done and at what cost? Preferably around Bukit Batok, Clementi or Bukit Panjang area? My steering tends to vibrate when driving at speeds above 100km/hr; I believe this would solve the problem. You can consider Stamford Tyres at Lok Yang Road and their service is . Link to post Share on other sites More sharing options...
Solar Turbocharged February 1, 2009 Share February 1, 2009 if your rim/tyres are problematic, or your alignment is off in the first place, no amount of balancing will solve the vibration issue.. it helps to eliminate a possibility though Link to post Share on other sites More sharing options...
Try_conti 2nd Gear February 1, 2009 Share February 1, 2009 What was your last change before you encounter this problem ? Link to post Share on other sites More sharing options...
Saabest 2nd Gear February 1, 2009 Author Share February 1, 2009 sorry about the wrong folder. I rotate the tyres at 40,000km barely 2 weeks ago. The mileage now is 42,000km. I do not think alignment is teh cause of the wobbly steering as car did not drift left or right when crusing at high speeds. Thanks for all th einput anyway. Link to post Share on other sites More sharing options...
Skxly Neutral Newbie February 1, 2009 Share February 1, 2009 Check your front tyres for any nail or stone stucked or foreign body. My old Sunny had such an experience but the tyre really gave way after going at high speed along the NSH. Safety first ... don't go at high speed until you find the root cause. Link to post Share on other sites More sharing options...
Xspace 1st Gear February 1, 2009 Share February 1, 2009 Stamford Tyres @ Lok Yang... After doing for you, the svc mgr will take ur car, go out for a spin and test... I juz did there, problem resolved. Oni cost me $20 like tt... Link to post Share on other sites More sharing options...
Kyojin 1st Gear February 1, 2009 Share February 1, 2009 do both an alignment and wheel balancing. if both doesn't help, it could be a steering issue - ball joints, tie rods, etc do you feel the brake pedal pulsating when you do hard braking? if so, then could be a warped brake disc. Link to post Share on other sites More sharing options...
Ady75 Neutral Newbie February 4, 2009 Share February 4, 2009 a good wheel balancing is all dat u need..frankly,i never done any high speed balancing on my wheels before, but i do not encounter any vibration on the steering at high speed.. Link to post Share on other sites More sharing options...
inlinesix Hypersonic February 4, 2009 Share February 4, 2009 I rotate my wheel, wheel balancing & hi spd balancing & alignment every 10k. For alignment, as long as there is no major deviation, i will not adjust it. Link to post Share on other sites More sharing options...
Raceguysg Neutral Newbie February 12, 2009 Share February 12, 2009 eh for stamford tyres right, can u just drive in and ask them help u do balancing on the spot or must make appointment? Link to post Share on other sites More sharing options...
Picanto 3rd Gear December 25, 2009 Share December 25, 2009 just walk in will do Link to post Share on other sites More sharing options...
Jeffhall009 Neutral Newbie December 25, 2009 Share December 25, 2009 I think you can find better options and solution for this. Just have some expert suggestions. Link to post Share on other sites More sharing options...
Raining Neutral Newbie December 25, 2009 Share December 25, 2009 i suppose expert opinion from trusted workshop better idea... but tends to cost more i suppose... as a bro mention above for $20 for balancing should lest remove 1 possibilty perhaps more financial prudent.. if dont work then seek workshop check better... Link to post Share on other sites More sharing options...
Zack2222 1st Gear January 14, 2012 Share January 14, 2012 What the price roughly for on car wheel balancing? Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 17, 2012 Share January 17, 2012 hIGH speed on the car balacing is not GOD can solve all steering vibation issue for the last 2 decades most car 99.9 % no need this kind of job . ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre Rotation and balancing
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Are You A Big Spender For A High End Bed Mattress?
Wheel Hubs
Wheel Hubs
