Yc86 Clutched October 8, 2005 Share October 8, 2005 ok... will go look for it now. mm.. its more for shutting down engine after a 'hard' run. then leave the fan on longer to cool it faster.. cos the fan shuts off after about 30sec then i feel very hot for the engine. no turbo timer or fan timer so manual switch lo ↡ Advertisement Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 8, 2005 Share October 8, 2005 ic...it shd be quite easy to do cos i saw my mech did the bypass without my consent. I went back and kao peh them Link to post Share on other sites More sharing options...
Yc86 Clutched October 8, 2005 Share October 8, 2005 heheh... the problem is just finding it.. anw i can't seem to find it. looks like a little plastic tube right? if can't then need some help during the meetup sorry if i seem to have a 100 questions... sources for this car is very limited. planning to wire up the sunroof motor too (motor came with open ends) but got stunned cos the motor wiring have so many colours (blue, brown green... etc) was just expecting the red and black.. hai so frustating and complicating... and now i can't drive at night cos after changing the diy open pod intake, idling became screwed and when i turn on the lights the engine dies. even the aircon compressor on engine also dies at idle. *pulls hai* Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 8, 2005 Share October 8, 2005 it is house by a silver metal housing, behind this housing shd be the plastic tube that u have mentioned. Sure no prob, can show u during meetup. oh, quite strange that the open air pod intake affects the engine...too much air? shdnt be. I had this engine died 3 days ago when i was hitting 4th gear and after off A/C, car back to normal. Hence drove to mech and found alternator "ki chia" liao. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 15, 2005 Share October 15, 2005 dunno suay or wat...today morning found passenger door handle mechanism spoilt...cannot open door from outside. So went admiralty west yard to look for replacement...spend abt 30 bucks with labour.. Link to post Share on other sites More sharing options...
Yc86 Clutched October 16, 2005 Share October 16, 2005 (edited) was it a new or from a scrapped car? my driver side spoil before then had it changed for $55 inc labour at bt merah.. supposedly original suzuki part as seen on the wrapper think my passenger side going to give way soon... feels kinda loose n still havn't fixed the rubbers yet... feeling to mod > feeling to replace worn parts Edited October 16, 2005 by Yc86 Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 16, 2005 Share October 16, 2005 I got the replacement from a scrapped car...I went with the mech to the scrapyard...juz next to his mini workshop to look for the handle.. Think urs shd be also from scrapped but probably respray to look nicer. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 25, 2005 Share October 25, 2005 Changed a recon alternator....1st one died after 2 weeks..2nd one last saturday. Hopefully can last for couple of yrs. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 25, 2005 Share October 25, 2005 Quote Hmm...send it to my mech...he is unable to arrest the sound...coz sometimes have sometimes dun....so he just oil the sus and doors for me... I'll like to try other mechs...any recommendations? ========================== Check the rubber bushings on the rear trailing arms & the ARB. I also have sound for some time already & narrowed it down to the bushings. Going to get them changed when I have some time. Had the sound even with brand new shocks so cannot be my shocks. Let us know if yours is also the bushings. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 25, 2005 Share October 25, 2005 Quote hiz~ my swift is leaking water!the rubber on the window linings and rear windshield have gone bad i guess.. especially when i parked under the hot sun for a whole day and parts were cracked open. don't dare drive in the rain.. and washing it has become a chore as have to clean the inside of water also.. anyone changed the whole car's set of rubbers before and how much did it cost? thnx ========================= Consider using a silicon sealant. Apply it around the whole windshield where the balck rubber meets the glass & also metal body. Follow the instructions on the tube. I used selleys b4 & it worked to stop the leak for several years till I sold the car. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 25, 2005 Share October 25, 2005 juz did a diy session...found again leaky coolant at top rubber hose... i pull out the hose out...all green coolant from that portion drained out.. Next bought from hardware shop the same ring hose fastener (screw type) for $1...and that $$ simon charged me $4 each then. Put the fastener through the hose and use my bull strength to go through the top housing valve. Then tightened the fastener. Top up radiator... Perfect...better than simon ...zero leak Link to post Share on other sites More sharing options...
Yc86 Clutched October 25, 2005 Share October 25, 2005 i tried silicon for the rear windscreen.. kinda messy to apply unless use fingers but still looks like some kindergarden kid did it.. and some of it peals off when drying with cloth too.. or should buy those industrial strength kind that comes in a big squeezie thingy... Link to post Share on other sites More sharing options...
Ex_vagrant Neutral Newbie October 25, 2005 Share October 25, 2005 Bro, go there boh jio!! Link to post Share on other sites More sharing options...
Ex_vagrant Neutral Newbie October 25, 2005 Share October 25, 2005 Hi...thanks for your help. I've already resolved the grock-grock sound from my ride. Replaced the lower arm joint and the rubber caps (with my mech applying lotsa grease). No more sound liao till today. Is this what you meant by bushings? Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 26, 2005 Share October 26, 2005 go where?? simon..wahz that one is kana tow onez...not my choice cos car died...alternator not charging Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 26, 2005 Share October 26, 2005 Ah so. U r lucky that the leak was at the clip part. Just cut away the part of the rubber hose that has the leak & if not too much, just put the hose back & tighten the metal ring clip. If the rubber is still in good condition, can use sommore. But make sure the rubber is not soft or cracked or bulging. Then it's time to change the hose. Remember to also check the bottom hose & any other hoses for worn rubber. Might as well check both at the same time just in case. Simon charge $4 for the ring as he will tell u his is from USA. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 26, 2005 Share October 26, 2005 Maybe u can try this: Place sticky or scotch tape along the top & bottom edges, making sure it's free of dirt & oil/grease, exposing the areas u need to silicon. Apply the silicon evenly & when slightly set, remove the tape. This will give u a neat edge to the silicon. It will flatten off as it dries to leave a thin flim to seal against leakage. Do the whole windscreen edge if u not sure where the water enters. Let it dry in the sun if possible for a few days b4 touching it. It sud b pretty durable by then but just b extra careful when u wiping the area. I used Selleys Silicon in a tube the size of a toothpaste tube. Dont use the industrial type they use to stick glass windows together. This type will NOT flatten out as it dries & will look ugly. Look for the type that leaves only a thin film as it dries. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 26, 2005 Share October 26, 2005 Rubber bushings r like rubber plugs which prevents the two pieces of metal from touching or rubbing against each other when the part moves due to the suspension set-up moves up & down, with the bolt or ARB going tru the hole in the center. Anyway glad u solved your problem, but if the rubber is already worn, the sound will come back when the grease rubs away. Only way to solve then is to change the rubber. ↡ Advertisement Link to post Share on other sites More sharing options...
Cars after 10 years coe
For car newbie: Website on DIY Car Maintainence
Suzy Pics
Suzy Pics
Qn on K&N Maintainence
Maintainence
Maintainence
Alcantara Maintainence
