LED FOG LIGHTS
Wire
Any Bros here know where we can get LED Fog lights in Singapore?
I think they come in diff colours. White, blue, red and orange.
These are from PIAA.
[inline led1.jpg]
[inline led2.jpg]
[inline led3.jpg]
[inline led4.jpg]
[inline led5.jpg]
[inline 03_bmw.jpg]
[inline elgrand.jpg]
[inline erision.jpg]
[inline noa.jpg]
[inline oddesei.jpg]
[inline voksi.jpg]
[inline wish.jpg]
Hi, saw them b4 at the accessory shop besides new world plaza jalan besar mkt. Not sure if it is PIAA or not. U can try your luck there.
Thanks for your advise.
How about theses?
They are not LED type but not sure if they are approved or not.
By the way, any website where we can check if legal.
[inline fogs.jpg]
[inline Fogs1.jpg] [inline fogs2.jpg] [inline fogs3.jpg]
Any time. BTW any aftermkt fitted fog light are illegal in the eye of LTA. U still can fit but must cover (that means use oni when out of s'pore) or use at ur own risk here. Reason is LTA have requirements on where they can be fitted & will they overload ur electrical system causing fire hazards.
http://www.onemotoring.com.sg/publish/onem...ml#MainPar_0009
Fog lamps[/url] statics.0.gifstatics.0.gifmodification_allowed.MainPar.0010.Image.gifThe following requirements must be met when installing aftermarket fog lamps:
a) The fog lamps should bear approved markings to show that they have met internationally recognised standards. If they meet ECE regulations, they will bear markings, 'B' and 'F' for the front and rear fog lamps respectively.
b) If the fog lamps do not bear any markings, check with the vehicle's importer or agent to see if these fog lamps are originally fitted or approved by LTA
c) The front fog lamps must cast a white or yellow light. They must be installed not more than 400 mm from the sides of the vehicle and at least 600 mm apart from each other. They should also be located below the headlights and at least 250 mm above the road surface.
d) The rear fog lamps must cast a red light. They must be installed not more than 400 mm from the sides of the vehicle and be at least 100 mm apart from the stop lamps. They should also be located between 250 mm and 1000 mm above the road surface.
Fog lamps can cause unwanted glare when improperly installed. Therefore, the installation must be carried out by qualified personnel in accordance with the product manufacturer's recommendations.
Note: If the fog lamps do not meet the above requirements, it must be covered at all times when the vehicle is being used in Singapore.
Thanks.
So troublesome one hah.
Thought of installation another 2 more smaler fog lights or LED (currently already have 2).
