Help, i fuse the fog light...
Ahdi
Was washing my dad's car jus now....E200 Komp
the fog light alignment wasn;t accurate, discover it for v long liaoz.....so jus now wana align it.....
took out the cover and started adjusting it...inside feels hot cos i on and off the fog light to check...
took a spanner to adjust...accidently touched the plus together with the minus of the bulb.....heard a zzzz sound and there goes the fog light....fog lamp using H1 bulb....
both sides no light..even the interior fog light lamp has no light..
believe i short circuited the fog lamp...
can anyone tell mi wad could be the likely problem and where can i repair it?
C&C is fxxking ex, so wun wan to go back..wad about stamford tyres?
Edited by Ahdi
Don't worry, it should just be a fuse thats blown.
Check the kick panels in the front seat footwells for a removable cover. Fusebox will probably be there with some spare fuses on the inside of the cover.
Pull out each fuse one at a time and put them back in if they're still connected. Do not mix the fuses up as they are of different amps. If the one in the cabin doesnt have the blown fuse, then check the bigger fuses in the engine bay.
If it isnt there there might be one somewhere in the boot as well. Sorry, but i don't know exactly where the box is, just used the normal locations for them for you. Also check the manual to see if they show you where it is.
Edit: check the small fuses first as they are more likely to be blown than the bigger ones in the engine bay.
Edited by Elfenstar
Just go to any car audio shop... they should charge less than $10 for testing & replacing the fuse.... I replaced mine near chomp chomp (Serangoon gardens for $5 only...)
ya..thanks thanks...went stamford tyres ask them to check, they help mi to check thru all the fuse..everything.....charge mi $15..plus realignment of the fog light....
