Nine_eleven 2nd Gear July 12, 2005 Share July 12, 2005 issit possible to 'upgrade' our car's oil sump to accomodate 1 quart more of oil? most cars run a 3.78litre capacity oil sump, would it be possible, and cost effective to change the pan to a larger capcacity one (ie 4.7litres) more oil means cleaner engines... practical mod? ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear July 12, 2005 Share July 12, 2005 Damn difficult to do so. Unless you run bypass setup. You will effectively get 5 more quarts in capacity . But it is expensive and uses lots of tubes and stuff. Prone to leaks. Not cost effective unless you are running a delivery rig that runs day in day out clocking lots of mileage. Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear July 12, 2005 Author Share July 12, 2005 wouldn't a deeper pan do it? Link to post Share on other sites More sharing options...
Genie47 1st Gear July 12, 2005 Share July 12, 2005 Yah you can but how deep. If get too deep must raise the suspension or else can start scraping whatever is underneath. Bigger oil sumps are not sought after for lube solutions in many cases. Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear July 12, 2005 Author Share July 12, 2005 hmm... ok ...just a thought... but it seems like a simple solution Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 12, 2005 Share July 12, 2005 Ok, possible but engine dependant. There SR20DET on the S13-S15 silvias have very shallow sumps which sometimes causes oil starvation when drifting. Lot of drifters have changed to larger sumps with internal baffles. It costs appox AUD$600 for a trust/blitz/etc sump. There are cheapo china copies, but the quality is bad and often there are shavings still in the sump that can only be removed by 2hrs of scrubbing with a scourer and some harsh chemicles. Some people who have used the cheap copies ended up with engine failure. Why do you want a larger sump for??? Even with the shallow ones in the SR20DET, there have been no issues except in motorsports. Link to post Share on other sites More sharing options...
Fortress Clutched July 13, 2005 Share July 13, 2005 Save your money my friend. You must as well change your oil and filter more often. For 4.7 l, you have another practical problem, buying addition 1l for the sump. ↡ Advertisement Link to post Share on other sites More sharing options...
Upgrading stock horn
Test forum upg
Test forum upg
BMW 523i F10 Highline 10 Years COE Renewal
Survival of the fittest, we shouldn't waste anymore pocket money
Opinions about upgrading
Leopard 2 tank upgrade
Mazda Bose System upgrade
