Xiaogary Neutral Newbie July 1, 2005 Share July 1, 2005 My fog light is currently using H27 connection. Can I change the connection type with any adapter? Hope to change it to HID, so that can use in malaysia darker roads. My H4 headlight, I prefer it to remain normal bulbs for normal road usage. ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear July 2, 2005 Share July 2, 2005 do not use a 1 for 1 replacement fr halogen to HID, tat will cause ur adapter & cables to burn if u use the wrong fuse and tat can start an engine fire (note: 18% of vehicle fire starts here) you will need a total change for cable, special adapter, new fuses, etc. as long as u stay within the current rating, you r ok. notwithstanding this, there r certain bulb will hv better range. yu can check either PIAA or Osram. ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
Bulb replacement : help needed
Cost of changing headlamp bulb, foglight bulb
Will warranty void if change light bulb?
HID bulb in a Halogen Projector lens
Where is the best place to buy bulb?
House light bulb is too hot
HID bulb burst. Anyone know why?
