Nightfalls Neutral Newbie June 26, 2005 Share June 26, 2005 Dear all, Anyone can direct me to look for a manual trans gearbox for Jazz/Fit for conversion? I am running on a CVT..I am looking to convert... tthanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Hitman Neutral Newbie June 26, 2005 Share June 26, 2005 ... do you even know how expensive if not impossible the conversion would be Link to post Share on other sites More sharing options...
Nightfalls Neutral Newbie June 26, 2005 Author Share June 26, 2005 would you share? Link to post Share on other sites More sharing options...
Xiaogary Neutral Newbie June 26, 2005 Share June 26, 2005 why you dont like CVT? Acceleration faster than manual right due to manual wasting time to changing gears? Or you too inspired by Initial D and want a manual transission so that you can meddle with the gear stick and drift.... Link to post Share on other sites More sharing options...
Mavvy Clutched June 26, 2005 Share June 26, 2005 You damn right on it !!! I wouldn't imagine how much the $$$.. Link to post Share on other sites More sharing options...
Felipe 3rd Gear June 26, 2005 Share June 26, 2005 i seriously dun think the cvt is faster than the manual. u dun actually waste time changing gears. wat happens is u change it at an rpm that u like and u can actually do it quicker. and its five speeds, cvt shud be 4 speed rite...so tat gives closer ratios. but no point changing...alota paper work and besides its a highly complicated process. mayb if yrs is like selespeed or easytronic where its a fully manual car then its easier Link to post Share on other sites More sharing options...
Hitman Neutral Newbie June 26, 2005 Share June 26, 2005 You the nitty gritty details First and foremost .... 1) LTA .... they need to approve your change from an auto to a manual. What reason you gonna provide them ?? I dont like CVT is not reason enough 2) The whole gearbox and all the drive shaft components associated with it .... how to gonna bring it in ?? I dont think they got a manual gearbox for Jazz/Fit in Singapore. Maybe you can use a Honda City gearbox, and that will set you back a couple of thousands. 3) Your Jazz got clutch pedal ?? Dun have right ?? Have to fix that in. 4) ECU .... they got to remap and get you a new ECU ... thats another few thousands, with tuning and all. In summary .... there is a lot of components involved, not just mechanical components but also legality issues. ps : How old are you ?? Is this your first car ?? Link to post Share on other sites More sharing options...
Megalord Neutral Newbie June 26, 2005 Share June 26, 2005 The jazz has been sold for a long while with choice of MT and CVT, so the gearbox is available for jazz locally. However, its not easy to install one... But everything is possible with $$$. Care to share why you would want to change to a MT? The only reason i ever heard before is someone wanna TC his ride and thus wanna to get a robust MT instead. Link to post Share on other sites More sharing options...
Nightfalls Neutral Newbie June 26, 2005 Author Share June 26, 2005 (edited) TC ZZZZZZzzzzzzz...... planning only lah..nothing concrete Edited June 26, 2005 by Nightfalls Link to post Share on other sites More sharing options...
Panda Neutral Newbie June 26, 2005 Share June 26, 2005 Bro Hitman is right. Cost so prohibitive, you might as well sell off and buy another Jazz/Fit manual. The loss incurred is cheaper than conversion. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie June 27, 2005 Share June 27, 2005 cvt is not 4 spd, its just one gear which gives an infinite gear ratio. the pickup sucks, cant even compare to 4 spd auto. feels like an overstretched rubberband when u rev it. in short, cannot make it. Link to post Share on other sites More sharing options...
Clio Neutral Newbie June 27, 2005 Share June 27, 2005 (edited) theoritically CVT is a better transmission and can out accelerate a manual trans. FIA ban CVT in 1994 when Williams is trying to use it in the 1993. http://www.cke-tech.com/cvpst.htm check out: http://auto.howstuffworks.com/cvt.htm for more info. see how it performs against manual: http://auto.howstuffworks.com/cvt9.htm Edited June 27, 2005 by Clio Link to post Share on other sites More sharing options...
Hitman Neutral Newbie June 28, 2005 Share June 28, 2005 You damn right on it !!! I wouldn't imagine how much the $$$.. Link to post Share on other sites More sharing options...
Hitman Neutral Newbie June 28, 2005 Share June 28, 2005 Link to post Share on other sites More sharing options...
Nightfalls Neutral Newbie June 28, 2005 Author Share June 28, 2005 actually not quite true that pickup for Jazz sucks le.... ask any jazz owners, they will share with you the low end is good.. true the gear box might be a significant determinant in the pic kup, however engine specs also critical...the max tor for jazz is only around 2600rpm...so low end good.. correct me if i am wrong... Link to post Share on other sites More sharing options...
Mavvy Clutched June 29, 2005 Share June 29, 2005 if need to change , i would rather change car... probably cheaper solution.. Link to post Share on other sites More sharing options...
Mavvy Clutched June 29, 2005 Share June 29, 2005 Low end is .. Link to post Share on other sites More sharing options...
Jkl78 Neutral Newbie June 29, 2005 Share June 29, 2005 i not sure whether can b done on jazz... i hv a fren chg fr auto to manual in msia for ard 3k... ↡ Advertisement Link to post Share on other sites More sharing options...
Pre-2014 Honda Jazz / Fit (GD & GE Series)
BMW M Cars Are Done With DCTs, and Soon, Manuals Too
Looking for a manual car because real men use three pedals!
Mother of all Avian Influenza * (H*N*)
Acceleration -- CVT vs auto
Clutch for Volvo V40 T4 2013 Price?
