Which audio shop for troubleshooting?
Jusnel
Hi,
my HU, 2 days, can't play anything, out of sudden.... dunno why....
the whole unit just not working at all, radio also cannot play. even got no display lit up when start car engine. like there is no power connection to the unit.
at first, the sound/music is breaking when i play radio or CD. i notice that if the car is at free gear, the sound/music is ok, normal. But when i engaged 1st gear and start to move car, the sound/music will keep breaking away.....
I'm using a short shifter.
Then i keep trying to continue to use the HU. then suddenly, the whole unit got no display and nothing works already. no radio, no CD, no display lit up.
1st time, i encounter this problem.
any reliable and "no nonsense" audio shop, can recommend?
i using rockford fosgate brand unit. no CD changer and woofer. just a single CD player.
at the same time, my air con compressor is "dying" already. making alot of noise already. Does it got anything to do with the HU problem?
Edited by Jusnel
I suggest that you go back to the installer that installed your HU,
If you dun the install, then try to fix the air con compressor first.
For your symptom, it seems that it is a electrical problem. Get someone to look into that first before we rush into the conclusion that it is a HU problem.
thanks man.... i suspect it's an electrical problem.... i will fix up the air con compressor first then, and get someone to look at the electrical part.
