Cbx750p 1st Gear May 28, 2006 Share May 28, 2006 (edited) Quote well....found that the sponge underneath the front passenger side carpet (it's not the car mat...you have to lift up the carpet) was wet. decided to send to SA for a check....it was the air-con pipe (whatever u call it....it's the one that carries out the air-con condensation water) that was bringing the water in....need 2 days to dry to the manager a while....got a courtesy car ( not bad)..... collected my car today at 7+ pm ....checked....found some scratches on the interior plastic .......was promised a replacement.....so went home. opened boot......boot light not working trade off - "save" time by letting others dry my car, but gotta go back for the plastic and boot light OR spend a day drying the car myself but with no other trouble....i don't know My BiW had the same complaint ! It is 30% design fault on the aircon housing and 70% fault on the front passenger long legs and itchy foot ! I studied the design and though the factory had a shield over the drain outlet ( located inside the car ! ), the rubber hose connecting the outlet is still exposed to the front passenger long foot ! It is not easily reached but with a very long foot, it would dislodge if it is pushed repeatedly ! They need to improve on this ! What to do when you are making out in the car and the other partner is so excited and kicking kicking all the time ??? Lucky for me, the Optra drain outlet is located outside the vehicle ! No wet carpet problem ! CBX Edited May 28, 2006 by Cbx750p ↡ Advertisement Link to post Share on other sites More sharing options...
Lukie102 Clutched May 29, 2006 Author Share May 29, 2006 didnt take a look so not sure. i had 2 'wet' incidents after this. they blamed it on the ICE installation. said the rubber shield or something on the firewall wasnt put back properly after tapping the wire in from the battery. I can accept this explanation when it's the front passenger side but the 3rd was at the driver side leh... my fren likes to stretch her legs in my car Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 5, 2006 Share June 5, 2006 Quote This would be a very serious matter. I would screw the SA in this case. If theres water, you'll be looking a corrosion. If corrosion takes place, that particular part of the chassis would probably be the first to break off in an event of a *touch wood* crash. Have it inspected for corrosion just to be on the safe side. I used to bring in wet umbrella under heavy rain and the whole carpet is wet. Would that also caused corrosion? Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 25, 2006 Share June 25, 2006 I just went for my 10K servicing at SA Leng Kee. Although appointment is 8.30 a.m. I reached there at 8 a.m. The door is opened and the cleaner told me the service guy is around. Within 5 mins he was out and attended to me even it is just 8.15 am! I called them at almost noon and they told me the car is ready. My right brake light is not working and they checked and found to be loose contact. I told them my steering seem to tilt towards the left and they rotate my tires. So what more do you want from Starsauto? Maybe I am quite easily satisfied one lor. Link to post Share on other sites More sharing options...
Cbx750p 1st Gear June 25, 2006 Share June 25, 2006 Like yourself, I think SA have made very good effort to satisfy all their customers. Only problem is, some of us think that our 5cts are as big as a bullock cart wheel and demand so much from the dealer, they bleed from the 7 holes on their body. Guess Singaporean are in general, a difficult bunch of people to satisfy. Some are easier whilst some are hard and some others are impossible unless the dealer bend over and do a head dance for them ! CBX Link to post Share on other sites More sharing options...
Genie47 1st Gear June 25, 2006 Share June 25, 2006 If not easily satisfied, DIY. Like what those villians in movies always say. If you want something done, you don't send your henchmen. ↡ Advertisement Link to post Share on other sites More sharing options...
Parking Idiot / Parking Fail / Anyhow Park...
SAFRA Clubs : Benefits NSF or Another Entertainment HUB?
Monkey think, another monkey do
Another ICA boo boo . . . .
Another no horse run kindness act.
