Lukie102 Clutched June 20, 2005 Share June 20, 2005 well....found that the sponge underneath the front passenger side carpet (it's not the car mat...you have to lift up the carpet) was wet. decided to send to SA for a check....it was the air-con pipe (whatever u call it....it's the one that carries out the air-con condensation water) that was bringing the water in....need 2 days to dry to the manager a while....got a courtesy car ( not bad)..... collected my car today at 7+ pm ....checked....found some scratches on the interior plastic .......was promised a replacement.....so went home. opened boot......boot light not working trade off - "save" time by letting others dry my car, but gotta go back for the plastic and boot light OR spend a day drying the car myself but with no other trouble....i don't know ↡ Advertisement Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie June 20, 2005 Share June 20, 2005 That pipe is the drain off hose which suppose to discharge the water droplets from condensation in the Cooling Coil. Obviously the hose is disconnected by any means and the water dropets did not get discharge out of the cabin and thats y the sound damping under the carpet was soaked.. Luckily you have that remedy fast or else you will have infested ants and roaches.. BTW what car did they loan you for replacement?? Link to post Share on other sites More sharing options...
Lukie102 Clutched June 20, 2005 Author Share June 20, 2005 i m quite paranoid of water in the car.....i discovered it when i was cleaning the car mat and found a round spot of water on the underside of the mat and decided to investigate else usually ppl wldnt find out. i am afraid of rust actually.... a manual aveo hatchback.... Link to post Share on other sites More sharing options...
Botak Neutral Newbie June 20, 2005 Share June 20, 2005 No 747 is it? Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie June 20, 2005 Share June 20, 2005 This would be a very serious matter. I would screw the SA in this case. If theres water, you'll be looking a corrosion. If corrosion takes place, that particular part of the chassis would probably be the first to break off in an event of a *touch wood* crash. Have it inspected for corrosion just to be on the safe side. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 21, 2005 Share June 21, 2005 yupz... the courtesy car was 747... damn jialart... Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie June 21, 2005 Share June 21, 2005 that 747 is used by the Angmo to travel from home to SA. You should see the way he close the driver's door. 150pounds of hand muscle to close the poor door. If the door got life, it would scream until it dies... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 21, 2005 Share June 21, 2005 OIc... and the fact is... that car stink. Link to post Share on other sites More sharing options...
Lukie102 Clutched June 22, 2005 Author Share June 22, 2005 my spokesman have answered you Link to post Share on other sites More sharing options...
Lukie102 Clutched June 22, 2005 Author Share June 22, 2005 shld be okie since they have dryed it Link to post Share on other sites More sharing options...
Skthk Neutral Newbie April 14, 2006 Share April 14, 2006 Quote i m quite paranoid of water in the car.....i discovered it when i was cleaning the car mat and found a round spot of water on the underside of the mat and decided to investigate else usually ppl wldnt find out. i am afraid of rust actually.... a manual aveo hatchback.... So it's Aveo5 ? Please comment how is it ? What made u chose it over others hatchback like Rio/Getz/Swift ? I am very curious why so many Getz so little Aveo5. Was think Getx very nice until see interior of Aveo5, seems to made Getz look cheap. But more headache as got New Aveo Sedan which is just $1K more !? Link to post Share on other sites More sharing options...
Lukie102 Clutched April 15, 2006 Author Share April 15, 2006 mine is aveo hb. why? cos it's cheaper and the new getz and rio not out yet. but anything, space wise aveo wins getz. got some problem, changed stabilizer bushing and 1 of the front link rod. there's sound coming from the front. now there's sound from right back when i m turning with full load. will ask mech to check. Link to post Share on other sites More sharing options...
Brock 1st Gear April 15, 2006 Share April 15, 2006 Lukie, When did you change your stabilizer busing and the link rod? At 20k? How long did it take? Labour charges came up to how much? They told me that they will replace mine at 20k! Link to post Share on other sites More sharing options...
Lukie102 Clutched April 16, 2006 Author Share April 16, 2006 bushing ard 20k. link rod ard 30k+. why you need to change?? FOC cos it should not be wear and tear fault. link rod should last longer if you dont go off-track or fly over bumps. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 16, 2006 Share April 16, 2006 Make sure the floorboard is fully dried & do check if there r any signs of rust. If so, apply a coat of "rust converter" to make sure it dosent get worse. The matting & carpet cud b dried very quickly by using a hair dryer. I think they left your car in the sun with all doors open which caused your boot light to blow as it was on for a few days. The AC water pipe sud b checked if it is blocked. If it is or not fully cleared, the water problem will come back. Link to post Share on other sites More sharing options...
Lukie102 Clutched April 16, 2006 Author Share April 16, 2006 It should be dry since it happened so long ago Boot light blew? They told me the connection was not fitted properly There's no more water coming in but I'll ask my mech to double check. I have decided to forsake them. Link to post Share on other sites More sharing options...
Nicoduc Neutral Newbie May 1, 2006 Share May 1, 2006 I oso Link to post Share on other sites More sharing options...
Lukie102 Clutched May 1, 2006 Author Share May 1, 2006 also what?? ↡ Advertisement Link to post Share on other sites More sharing options...
Parking Idiot / Parking Fail / Anyhow Park...
SAFRA Clubs : Benefits NSF or Another Entertainment HUB?
Monkey think, another monkey do
Another ICA boo boo . . . .
Another no horse run kindness act.
