Mondeo Neutral Newbie April 7, 2002 Share April 7, 2002 Anyone knows where can get including installation. ↡ Advertisement Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 7, 2002 Share April 7, 2002 Braking hard eh? Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 7, 2002 Author Share April 7, 2002 Want the braking power more. My stocks are quite spongy. Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 7, 2002 Share April 7, 2002 Why dont you change the pads first? They might do just fine Cheaper somemore! If its still spongy, can think of this instead! Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 7, 2002 Author Share April 7, 2002 Pads and brake lines also need to be changed. Those money can not save lah. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie April 7, 2002 Share April 7, 2002 You can check with Speedworks. Mr Loo carries Sparco steel braided hose (got mine from him). If you finally manage to find a set, do contemplate using DOT 5.1 brake fluid too, since you gotta bleed the fluid while changing the hoses. While you are looking, maybe you can consider Brembo Max slotted brake disc too! Agree with you that braking power must be optimised and that money for these stuffs cannot be saved! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 7, 2002 Share April 7, 2002 CS Autolabs or Autofix can do custom S/S braided hose for you (Goodridge brand from UK). They'll need your car there so that they can crimp the hose to your stock brake line connectors. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 7, 2002 Author Share April 7, 2002 Yes, must use DOT 5.1, how much for u set? Brembo or Brembo Max has yet to develop for My Mondy. PCD108 x5 /CB 63.4mm Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 7, 2002 Author Share April 7, 2002 Address & abt $ please Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 7, 2002 Share April 7, 2002 Hmm...true true! Safety first! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 7, 2002 Share April 7, 2002 CS Autolabs is at Blk 17 Sin Ming Ind Est, Autofix is up at Sin Ming Autocare. Cost around $220 per set. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 8, 2002 Author Share April 8, 2002 Tks. will go down after the next week. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 8, 2002 Author Share April 8, 2002 Have U installed? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 8, 2002 Share April 8, 2002 I got my braided hose from a Volvo tuner in the US so it's made to fit type, not custom. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 8, 2002 Author Share April 8, 2002 Any comments of their job? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 8, 2002 Share April 8, 2002 Donno, but have plenty of Jap cars done by them so far no complains on forums. Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie April 8, 2002 Share April 8, 2002 Hi TB, How many sets are required for a car? BTW, will this void the warranty of the car? Thanks. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 8, 2002 Share April 8, 2002 4 hoses per car, shouldn't affect warranty unless the hose breaks then must go back to the workshop who did it rather than agent. Mondeo is going to Autofix to check it out, let's wait for his field report ↡ Advertisement Link to post Share on other sites More sharing options...
More MRT Lines Announced
Brake Pads
Brake Pads
Steel cabinet
Steel cabinet
Brake squeak every morning
