Is it time to change my speakers?
Marcz
when i pump the volume, my right side speakers goes weird and starts producing a "zee zee zee zee zee" sound, sometimes its there sometimes its not there..i took apart the side and saw that the cone didnt' crack or anything, what cld be the problem?
Edited by Marcz
Problem may not be the speakers, it could also be your HU, amp, cables, etc.
Got to isolate one thing at a time to confirm. Best leave this to an installer unless you're knowledgeable in your system.
Good luck!
it ONLY comes out at the right speaker..and it sounds like something is lose inside...
Edited by Marcz
What speakers are you using now bro? How long is the speakers?
Mine also the same, check by the installer, he say overload liao....
possible the terminals r not tight. also, the speakers should b affixed with rubber gland/ washer/ spacers so they do not hv direct contact with the door panel. lastly, good installers will fix rubber behind the cone if u hv no sound proofing, else the metallic movable parts like door handle bars, winodw winding cables will reverbrate.
some stock speakers...used since 2001...
what u mean by overload ?
Edited by Marcz
