Shocks
Konspire
definitely more firm and less comfortable tham stock....you have to compromise when you want performance handling....
the coil, do you mean the spring? I dont think need to change, spring can last quite long, unless you want the lowered, performance type. I change to Hotbits spring after i get bumpy ride from cut spring.
the shop is at yew tee ind park, blk 1
Eng Hup, look for Simon. they have monroe($55+), takiko($40+),koni($110+) shocks too. but the koni quite exp as compare to selegie spareparts($420+ if you buy 4).
hope this help. [thumbsup]
r they good enuff as I used to have my car full. Like I used to bring around my parents so I don't want to get my car tilted behind, u knoe when you have full load, the car tends to get lowered behind due to the weight. So any1 could suggest me which shocks is the best, and reasonably priced. Anyway, u have the address or contact of selegie spareparts? thx a mil....
After market performance shock and spring will definitely be stronger than stock one as they are being made to withstand greater stress tahn stock....
So, having a full load is OK....Just look for those that don't drop too low...1" to 1.5" drop is adequate and don't have too big a rim and tyre combination......
ANd, of course, go for the proven ones and branded ones....
