Madman Neutral Newbie April 29, 2005 Share April 29, 2005 Hi all, I have been driving the Aveo Sedan Auto for slightly more than a week now. For a Korean made (another way of saying cheapo....) car, I must admit that I was surprised by the overall drive so far. I do not really subscribe to the below 2K rpm run-in mantra though. However, I made sure the needle does not go beyond 3K. Crusing at 100kmh on the pie is a joy. Sound proofing is one thing I like most about this car. I have driven the excel, corolla and laser before and I am pleasantly surprised that such a cheapo make could surpass even the corolla in that department. Bravo indeed to Daewoo On thing I have not tried concerning this car is the ABS. I wonder if anyone in the forum have had any experience in using this functionality. Would be glad to hear your experience. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Nerd_on_wheels Neutral Newbie April 29, 2005 Share April 29, 2005 dun think of it as cheapo, think of it as good value with pleasant surprises. The ABS works fine. Link to post Share on other sites More sharing options...
DarkLord 1st Gear April 29, 2005 Share April 29, 2005 Just try on your own at night lahz.. Link to post Share on other sites More sharing options...
Spango Clutched April 29, 2005 Share April 29, 2005 How to try it? Would trying it spoil it...? Link to post Share on other sites More sharing options...
Lanceteo Neutral Newbie April 29, 2005 Share April 29, 2005 i dun think it will spoil. jus hit the brakes? Link to post Share on other sites More sharing options...
Tploh Clutched April 29, 2005 Share April 29, 2005 Then how to know if it is good ABS or bad ABS ? Link to post Share on other sites More sharing options...
Madman Neutral Newbie April 29, 2005 Author Share April 29, 2005 Just slamming the brake pedal to try out the ABS is *not* the same as in real-life situation. What I would like to know is if anyone here has any real-life experience in near miss incidents in which the ABS had been a blessing. Perhaps we could learn a thing or two from others' experience, right? Link to post Share on other sites More sharing options...
Spango Clutched April 29, 2005 Share April 29, 2005 Haahaa.... I hit the brakes everyday but nothing happens leh... Spoil liao...? Link to post Share on other sites More sharing options...
Madman Neutral Newbie April 29, 2005 Author Share April 29, 2005 Hi Spango, when one is about to hit someone in front, for instance the car in front stops suddenly, especially on the x'way, one has to hit the brakes. Now, if one is in a ABS-less car, it will definitely skid if the driver does not let go of the brakes. So, the best the driver can do is to 'pump' the brakes - brake hard for split second, let go split sec, brake again, let go....and hopefully the distance for a complete stop is not too short. However, not many drivers have this skill. So, ABS comes in handy. In the situation similar to the above, the driver just needs to slam hard on the brake and steer the wheels. The ABS comes into play and ensure optimal braking w/o skidding. The whole car would vibrate, I think this is caused by differential braking by individual wheel, followed by a thun-thun-thun-thun-thun sound. I experienced this in my other car, a Toyota Wish. I was in total shock by the near miss, and would *not* like to experience this again, if possible. So, I wonder how the experience is like if I was in an Aveo facing a similar situation. Would like to hear from others of their experience. Thanks. Link to post Share on other sites More sharing options...
DarkLord 1st Gear April 29, 2005 Share April 29, 2005 Ermz... Okiez.. But mine car has four disc brakes... So far don't need to brake that hard to stop yet.. Link to post Share on other sites More sharing options...
Tploh Clutched April 29, 2005 Share April 29, 2005 Have you started your engine ? Link to post Share on other sites More sharing options...
Spango Clutched April 29, 2005 Share April 29, 2005 Ohh... That kind of hitting the brakes.... I've never experience that before, and I hope I never have to.... Link to post Share on other sites More sharing options...
Tploh Clutched April 29, 2005 Share April 29, 2005 But I thought ABS will give you longer braking distance than ABS-less cars ? ABS gives you more control during e-brake ( i.e. can steer away from object in front ), but will need longer distance to stop. Am I correct ? Link to post Share on other sites More sharing options...
Maded Neutral Newbie April 29, 2005 Share April 29, 2005 Mine's an Aveo HB, so I'm supposing we'll get similiar results. ABS on the Aveo works fine. Just slam on the brakes. Once the system detects that your wheels are in danger of stopping (relative to road speed), ABS kicks in and pumps the brakes for you. What you'll experience is a "recoil" (much like firing your M16 in full auto mode, but with the buttstock on your right foot ). Many newbies get confused when this happens and let go of the brakes, causing the accident or a near miss... As always, the grip of your tyres contribute significantly to how well your abs works. So if you're still running on stock 13" or 14s" i suggest you go get that changed ASAP... Mine came with Yokohama AspecDB... it's a really crappy excuse for a tyre.... Link to post Share on other sites More sharing options...
Maded Neutral Newbie April 29, 2005 Share April 29, 2005 If ABS kicks in, it means that on an ABS-less car, you'd have begun to skid... I think ABS stops you in a shorter distance, compared to a skidding car... Link to post Share on other sites More sharing options...
Madman Neutral Newbie April 29, 2005 Author Share April 29, 2005 Hi TPLOH, the ABS will prevent your car from skidding during hard braking, so you just need to stay really cool to steer away from the object infront if the braking distance is insufficient. Of course, this may lead to collsion with another vehicle when you steer to the left or right. So, the best policy is to allow a safe distance from the vehicle in front and not by tail-gating, so that one does not have to steer to the left or right but just slam hard on the brake and let the electronics do the work to stop the car before it hits the vehicle in front. Link to post Share on other sites More sharing options...
Tploh Clutched April 29, 2005 Share April 29, 2005 I think my understanding is correct, so I went to google to check. And I am. ABS car travel further than ABS-less car. Check it out yourselves. Go to fact no 6. http://www.csu.edu.au/division/healsafe/we.../guides/ABS.htm Link to post Share on other sites More sharing options...
Madman Neutral Newbie April 29, 2005 Author Share April 29, 2005 Hi Maded, mine are still stock 13in Kumho wheels. Feels quite OK. No complaints. Intend to change to maybe 15in in 1.5 to 2 yrs. Only then will have sufficient return on investment. If not, the finance minister (aka wife) will issue a spending freeze directive........ The stock items are quite nice, example the HU, component speakers, seat fabric, air-con. Actually, quite pleased with the buy Hopefully, the stock ABS system is just as nice as the other stock items. ↡ Advertisement Link to post Share on other sites More sharing options...
How Much Do You Know About ABS?
Mazda 5 ABS error
Mazda 5 ABS error
Understanding Anti-lock Braking System (ABS)
Effective remedy for motion sickness?
Effective methods to clean spilled sugary drinks in cat seat
How effective is PPS against bird droppings?
ABS warning lamp
ABS warning lamp
Enhanced Baby Bonus and the effective date
