Chris_ck Neutral Newbie December 12, 2002 Share December 12, 2002 My friend sprayed WD40 on his car's belts (alternator belt, aircon belt etc) and says it's good for the car as it keep the belt from being brittle or something. Any comments about this? Personally i thought WD40 is flammable and with the belt going at high speed can the WD40 withstand the heat and not combust? Or another train of thought with the added lubrication to the belts will it not cause the belt to not run as smoothly as before as friction is needed in turning the wheels (dunno the right term) attached to the belt. Anyone care to share his/her thoughts? ↡ Advertisement Link to post Share on other sites More sharing options...
Hitman Neutral Newbie December 13, 2002 Share December 13, 2002 Weird man !! WD40 at the belts. If you wanna keep your belts in prime condition, buy the belt spray at Autobacs. That is meant solely for your timing belts and all belts. WD40 is to ease friction ..... on the belts you need friction grip. I can't say whether its dangerous or not ...... but I certainly wouldn't do that ... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear December 13, 2002 Share December 13, 2002 Yup,.. Boobs is right.... I wouldn't do that too. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 13, 2002 Share December 13, 2002 Honestly, that's crazy Like MrBoobs suggested, get proper belt dressings and if necessary change your belts when they're due or worn Link to post Share on other sites More sharing options...
Chris_ck Neutral Newbie December 13, 2002 Author Share December 13, 2002 Ya i thought so too. so there is such a product as a proper belt spray? what are the benefits of it? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie December 13, 2002 Share December 13, 2002 To keep the belts supple. Link to post Share on other sites More sharing options...
Ek3stage 1st Gear December 17, 2002 Share December 17, 2002 proper belt spray? Just use normal silicone spray will do....no need waste extra $$...btw u do lubricate yr boots and other synthetic rubber, dont u. its to prevent from drying out, harden, crack, fray..... Link to post Share on other sites More sharing options...
Chris_ck Neutral Newbie December 17, 2002 Author Share December 17, 2002 Err.... what boots? the only boots i know is those i wear Link to post Share on other sites More sharing options...
Ek3stage 1st Gear December 17, 2002 Share December 17, 2002 those at the CV joints....they dont call them boots also? well not too sure abt any fancy names...i only know wat to be done... i can imagine the huge business of changing cv joints..... ↡ Advertisement Link to post Share on other sites More sharing options...
Can WD-40 restore your wiper blades ?
Cost to change the 3 belts (alternator/aircon/serpentine?)
This is why bus need seat belts
Why no seat belts for bus drivers?
Drive belts - Mitsuboshi or Bando or Contitech?
Approved adjustable seat belts for children
Squeaking belts only when cold
Installing 3-point seat belts
