Turbobrick Neutral Newbie December 9, 2002 Share December 9, 2002 (edited) Hi Guys, We are considering whether to bring in AMSOIL Series 2000 0W-30 with advance wear protection and fuel efficient formula. Highly recommended for repeated continuous high speed drive (like up and down the NS highway) and even for normal daily drives, it'll prove to maximize fuel efficiency. "Race-proven technology designed for passenger car performance. Provides unsurpassed fuel efficiency and up to twice the wear protection provided by popular conventional and synthetic motor oils." For more info http://www.amsoil.com/products/tso.html Indicative price will be about $25/quart (yeah I know it's a bit much). This oil surpasses Mobil 1 Tri-syn in wear tests! Recommended up to 3 times regular oil change interval We're NOT selling series 2000 yet, we want to gauge interest before deciding whether to bring in this racing performance oil. Cheers, Gavin Edited December 9, 2002 by Turbobrick ↡ Advertisement Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 9, 2002 Share December 9, 2002 interested but can my 6 year old brick use 0w-30? tot Vtim mentioned before older cars should go for 40-50? Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 9, 2002 Share December 9, 2002 (edited) Mojoe, if you have overhaul your engine than no problem . Else, IMO, you should stay with 50 weight old . Edited December 9, 2002 by Vtim Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 9, 2002 Author Share December 9, 2002 6yr old.....still can try but depends on which weight oil you previously used and issit mineral or Syn? Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 10, 2002 Share December 10, 2002 my first oil change after getting the car is Royal Purple from Shag... that's graded 40 right? engine not overhauled but dun see a lot of 50s around leh... the place i workshop that I go to now uses Liqui-Moly and Redline I think.. Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 10, 2002 Share December 10, 2002 wat's a good 50 one? seems like I dun see a lot of it... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 10, 2002 Author Share December 10, 2002 Well AMSOIL series 2000 do have 20W-50 primarily for track use (high engine temps and redlining all the time). If you can find kaki to make up 12quarts we can ship in a carton of Series 2000 20W-50 for you. Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 10, 2002 Share December 10, 2002 for track use? I dun go leh, and only rev up to a mx of 4000-5000rpm at times... still can ah? 12quarts about 12litres right?... hmm... so about 3 oil changes... dun mind getting it for my self actually... but at $25/quart is expensive though... close to $300 for 12 quarts Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 10, 2002 Author Share December 10, 2002 Nah, the 20W-50 is not specifically for track use, it's recommend for hard track use but since your engine is aged perhaps it's better. The tentative cost is $25 per quart but I'll see if I can work out a better deal for you if U get an entire carton.....will let U know again. Link to post Share on other sites More sharing options...
Luckcent 4th Gear December 10, 2002 Share December 10, 2002 1 quart = 0.965 litre Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 10, 2002 Share December 10, 2002 (edited) okay, thanks bro! ... but won't reduce by a lot right? wat about the 'normal' Amsoil? Do they have 50 one? The price for that is still alright for me... .. If I buy 1 carton of that, possible to order? Edited December 10, 2002 by Mojoe Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 10, 2002 Author Share December 10, 2002 Won't be much, the most 1 quart free (pay 11 bottles price for 12). The standard AMSOIL we carry is the High Performance Synthetic 10W-40 which is similar to what you're using now, that's $15 a quart Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 10, 2002 Share December 10, 2002 kinda figure... think I'll pass on the series 2k for now... The Amsoil High Performance oil comes in 50? My brick already clocked about 130k already so think i should go for 50.. Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 10, 2002 Share December 10, 2002 "Mobile 1" in 5 liter bottle offer at Carrefour goto : http://www.mycarforum.com/forum/gforum.cgi...ollapsed;#87931 Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 10, 2002 Share December 10, 2002 (edited) Mobil 1 has grade 50? Thanks bro! Edited December 10, 2002 by Mojoe Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 10, 2002 Author Share December 10, 2002 Actually the need to use a 50 series oil for old cars is really dependent on the oil change history of the car. My Taurus has 176k MILES on her and I'm using a 10W-30 oil and recommended from factory is 5W-30 all year round, and it's mineral oil. If you have been on Syn oil then I don't see a need to worry about using a 40 series oil instead. IMHO the need to use a 50 series oil is for constant high temp engine conditions or neglect of oil change and slugde had built up inside the engine and gaskets. Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 10, 2002 Share December 10, 2002 sigh... the problem is mine a 2nd hand one... not sure of history... only saw a Mobil 1 servicing sticker on the car which states supposed to change in June this year.. so assumed that the previous owner been using Mobil 1 syn... thanks bro! Link to post Share on other sites More sharing options...
Mojoe Neutral Newbie December 10, 2002 Share December 10, 2002 btw... good luck for the exams must score ↡ Advertisement Link to post Share on other sites More sharing options...
New Age Polish --> BMW Portfolio
WTB : NAUTILUS COMPACT SERIES
Self Import 5 series (G30) or X3 (G01) worthwhile?
BMW 8 Series 2nd Generation
Considering a PA plate minibus
