Martmode8850 Neutral Newbie December 20, 2002 Share December 20, 2002 hmm, that is interesting....glad to know that, but seriously, i have never tot that particles are able to go through the air filter, which is to filter off dirts and particulates and just left with air feeding into the combustion chamber.....good on u to spot that one yoh bro maz... K&N filters are sponge ones yah... normal filters are paper type. sponge allows bigger particles to enter the air-intake, while the paper ones filters off most of it. if you look are our engine compartment, it does collect some sand particles over time... so i guess the same will go for the combustion chamber. i have nothing against K&N and have many bros using it. just some adv and disadv to share... ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 21, 2002 Share December 21, 2002 Point to note, K&N filters are cotton based with wire gauze and oil imprenated. Sponge type are like HKS "mushroom" filters. Stock are paper Link to post Share on other sites More sharing options...
Flaser Neutral Newbie December 27, 2002 Share December 27, 2002 Yup, K&N filters are not sponge. Can refer to the following page for more info. Not sure if we can believe 100% of what is in the page, but I'm pretty convinced that it will filter just as well, if not better than, the normal paper filter. Or maybe I'm just a sucker for such marketing tech talk. http://www.knfilters.com/facts.htm Btw, can anyone enlighten me on the resonator removal? How do you actually do it? Do I need to replace it with another intake pipe, or just leave it open? Same thing with the sparks, had the Iridium put in, but didn't notice much difference. Felt it was money wasted, since stock sparks are so cheap to replace, so don't really need a long-lasting plugs? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie December 27, 2002 Share December 27, 2002 >>Btw, can anyone enlighten me on the resonator removal? How do you actually do it? Do I need to replace it with another intake pipe, or just leave it open? The resonator should be located just before the filter box. To be more specific, Outside --> Resonator --> Filter box --> Air flow sensor --> Throttle body --> Engine In order to remove the resonator, you need to expose it properly first. This may requite the partial removal of the front bumper. After removing the resonator, you can actually leave the opening as is but it may be better to attach a flexible tube and direct it to a strategic place where it can suck in cool air without sucking in water. The shorter the tube, the louder the induction noise will be. Of course it will be loudest if the opening of the filter box is left alone. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 28, 2002 Share December 28, 2002 The actual bhp per $ that a "superb" spark plug can produce is really not worth it. If you're mechanically inclined, changing standard copper plugs every 15k or 20k is fine. Fresh plugs gives me better assurance compared to leaving plugs in the engine for long periods.... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 28, 2002 Share December 28, 2002 A good practice for long service plug is to take it out to check at every servicing... ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Air Purifier Discussion - tips and info
DIY engine oil change
Recommendation for water filter
Dyson Zone, the real deal or has April fool's day come early?
Replacing fuel filter
TRD Engine Air Filter
