OBD interface point
Kopikao
Hi all optra owners,
check with you all is this the connection interface point for the OBD II?
Edited by Kopikao
probably not... check under your steering wheel.
Should look sumting like this:
[inline P1010061.jpg]
erm... On Board Diagnostics
whoops Genie answered already...
Edited by Maded
most ODB2 connector is found near the steering wheel column. [nod]
Only the ODB1 diagnostic port e.g. like tarzanboyz 323, is found at the right hand corner of engine bay. [sweatdrop]
Edited by Normal_aspirated
please check hor... that photo taken from the Aveo [;)]
Its under the steering wheel behind the panel, on the right.
Thanks man, found it, it under the steering wheel..just below the panel... [:p]
Hey, just got this off UK site.
How to make your dash-board indicator flash out the "morse-code" of the faults if any, without those expensive ones.
BUT, it seems like NOT our current Optra Engine, so not sure if the OBD is the same pins. And sure doesn't look like what you show in your pic
Usually, will not damage anything even if you stick the pins wrongly...
Anyone wanna try out first ? haha
http://www.topbuzz1.carenthusiasts.co.uk/....fault_codes.htm
http://www.topbuzz1.carenthusiasts.co.uk/....s/abs_codes.htm
Edited by Sotong_kia
