Noname Neutral Newbie December 4, 2002 Share December 4, 2002 Hi guys, I'm a noob when dealing with cars. Just got myself a 2nd hand 94Sunny right after I pass my driving test. Been driving for about 2 weeks now. Now it seems that my engine vibrate violently whenever I start the car in the morning. It is ok once I start moving off. My uncle is said it is a timing issue, but I don't understand what he means. Anyone care to explain to me And is it a dangerous thing? Sending the car for alignment next week so might as well as the guy to solve this problem for me. Thanks a lot for your help. ↡ Advertisement Link to post Share on other sites More sharing options...
Soya Supersonic December 4, 2002 Share December 4, 2002 Since it's a 94 model, it's probably worn engine mountings. Not really dangerous but quite irritating. What's your idling speed? (engine rev when stationary) Link to post Share on other sites More sharing options...
Noname Neutral Newbie December 4, 2002 Author Share December 4, 2002 (edited) I'm not too sure but I think it's about 1k. Will check it out later, but 1k if I do not remember wrongly. Only vibrate like crazy when starting, once I move off it's ok. Even when I stop at an intersection etc. Edited December 4, 2002 by Noname Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 4, 2002 Share December 4, 2002 Is your Sunny an auto or manual? If it's auto, get someone to check the engine compartment for you while U have the car in brake while shifting from "N" to "D" or "R". Whenever the tranmission is shifted the engine will shift either forward or backwards. If there is broken engine mount(s), there will be obvious knocking sounds from the engine compartment when the gear is shifted. Link to post Share on other sites More sharing options...
Noname Neutral Newbie December 4, 2002 Author Share December 4, 2002 (edited) It's a manual. Hey and thanks for the help guys. The guys in this forum are really helpful . Sending the car for checks on the 12th which is next week. Supposed to send it in this week but I had my first in camp after less than 6 mths I ORD. Edited December 4, 2002 by Noname Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 4, 2002 Share December 4, 2002 Humm....then it could be ignition timing or idle control problem. Try my mech Ah Lin at Blk 29 Sin Ming Ind Est #01-215, he charges resonably and very experienced with Jap cars. Great maintenance guy Link to post Share on other sites More sharing options...
Noname Neutral Newbie December 4, 2002 Author Share December 4, 2002 Thanks Turbobrick, I think that's the timing my uncle was referring to. Do you guys think it's ok if I put it off until next week. Cos I'm still under parts and service warranty. (Already made an appt with them) So don't want to go to other workshops first. And what is it really about? I mean the ignition timing. Link to post Share on other sites More sharing options...
Noname Neutral Newbie December 4, 2002 Author Share December 4, 2002 And I'll be sure to visit your mech after my warranty period is up Hear stories of noobs being ripped off. Since you recommend it, I believe it is trustworthy. Thanks for the info. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 4, 2002 Share December 4, 2002 OIC, since U have a service warranty I suggest let them take a look. Just tell them about the vibrations, don't need to suggest anything and see what they say. For ignition timing details check here http://www.howstuffworks.com/ignition-system.htm Link to post Share on other sites More sharing options...
Presea 3rd Gear December 5, 2002 Share December 5, 2002 Hi Noname, If your car is a 1.6L, then it's the same engine as my Presea. Maybe we can compare the 2 if we meet up....I used to have engine vibration problems due to a variety of problems.... I've also done a little bit of adjustments to the engine (only need a screwdriver) to adjust idle rpm speed.... Maybe at the next sanctioned MCF meetup... cheers Link to post Share on other sites More sharing options...
Noname Neutral Newbie December 5, 2002 Author Share December 5, 2002 I think mine is 1.4l Anyway me not a real car junkie, perhaps in the future Ok maybe one of these days, anyway me still very young only 21. Still studying. Link to post Share on other sites More sharing options...
Hungryforcar 1st Gear April 14, 2006 Share April 14, 2006 (edited) Does suzuki swift gti, engine vibrate too. Cos mine is vibrating not sure whether is the engine mounting problem or the natural of the engine since is over 15 yrs. regards Edited April 14, 2006 by Hungryforcar Link to post Share on other sites More sharing options...
Mivec9 1st Gear April 14, 2006 Share April 14, 2006 quite natural i must say....wat's ur idling rpm?? Link to post Share on other sites More sharing options...
Hungryforcar 1st Gear April 14, 2006 Share April 14, 2006 (edited) around 1 in the meter not sure is 1000 or less. with aircon fan running is vibrated too. if i installed a front strut bar will it help to min the vibration? Edited April 14, 2006 by Hungryforcar Link to post Share on other sites More sharing options...
Mivec9 1st Gear April 14, 2006 Share April 14, 2006 1000rpm..hmmm..ur next servicing, u ask mech to adjust say 1100 or so..see how the vibration.. Link to post Share on other sites More sharing options...
Hungryforcar 1st Gear April 14, 2006 Share April 14, 2006 hmmm..... i tap abit of acc, will reduce in vibrating but once in idlling mode, it vibrate and awhile later vibrate more and goes down, on and on, normal? last time i own a march, the vibration is not like massage car. i knw in the high speed it doesnt vibrate. if the engine mounting problem can i check visually Link to post Share on other sites More sharing options...
Mivec9 1st Gear April 14, 2006 Share April 14, 2006 my personal view is try to have a slightly higher rpm and monitor. When i got mine, i tot is the engine mounting too and the mech quote me like 200+ to change it...later found that it is common for our ride..hence didnt do it. not sure can check visually, think normally is thru inspection of vibration Link to post Share on other sites More sharing options...
Yc86 Clutched April 14, 2006 Share April 14, 2006 should be the ignition timing. easiest way is to try out different sparkplugs to see which suit ur engine setup... or u can manually adjust the timing ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
