Genie47 1st Gear April 6, 2005 Author Share April 6, 2005 Magnatec not fully syn. It is a blend. Yes, damn ex for 20% syn inside. The 15W40 is SL rated issit? ↡ Advertisement Link to post Share on other sites More sharing options...
Shorty Turbocharged April 6, 2005 Share April 6, 2005 i'm not sure.didn't check for de rating.anyway i dont quite understand de SL n SM thing.which is better?mayb tomrw i check n if it is s recommneded by u i'll buy.cos friday gotta go servicing. Link to post Share on other sites More sharing options...
Weezersg 3rd Gear April 14, 2005 Share April 14, 2005 Since the mobil 1 is so cheap now can use it for 1K servicing? I saw only left 5W30 type left at carrfour, that ok for 1K and subsequent service? It will not void warranty will it? since is not the 'recommended' oil? Pls advise, thanks. Link to post Share on other sites More sharing options...
Xavier Neutral Newbie April 14, 2005 Share April 14, 2005 I suggest that dun use such a thin oil if your vehicle have not break in yet. And it is a waste of such a good oil to drain out at 5k km. Use it after the 10k km servicing. Ideally, go for the cxxxxxe Triple R 5W40 $29.90/ 5L bottle(Fully synthetic) or Castrol GTX 15W40 $32/4L bottle. It gives better protection for your new engine. Link to post Share on other sites More sharing options...
Genie47 1st Gear April 14, 2005 Author Share April 14, 2005 Even though it is cheap, it is a waste. The oil IS that GOOD! Can last 15k km no problem. If drain out at 1k, you will feel the hurt. The M1 is worth its weight in gold and if can get cheaply, better reserve it for more intensive times. Link to post Share on other sites More sharing options...
Deus_ex Neutral Newbie April 16, 2005 Share April 16, 2005 hi...i have a complimentary car service package from CAS which they'll use 4 litres of multi grade engine oil(got it free from a magazine subsciption)...i just went for my 1k servicing n was told by the servicing guy that SA will use mineral oil up to 10k...but i need to use this complimentary car service package within 6mths or else it'll expire...is it advisable to use their multi grade engine oil at this stage when my car's still very new n running in? or is it better if i use it after the 5k servicing... any help would be much appreciated Link to post Share on other sites More sharing options...
Genie47 1st Gear April 17, 2005 Author Share April 17, 2005 If free, why not? Best to spend as little money as possible during break-in because the oil will drained at very short intervals. Very wasteful. Link to post Share on other sites More sharing options...
Littleblackalfa Neutral Newbie April 20, 2005 Share April 20, 2005 well, M1 is good. I assume you mean 0W40? but one thing. it probably won't happen in a chevy engine, but the oil IS a bit thin, and does break down faster than other oils in my car. Hell, I'm using 10W60 racing oil, and it still does break down... whahahaha... Link to post Share on other sites More sharing options...
Genie47 1st Gear April 20, 2005 Author Share April 20, 2005 (edited) The main gripe about the M1 0W40 is that it is rated 229.3 and it can't hold its grade past 5k miles. So many users these sorry numbers. Castrol SLX-A3 is rated 229.3 and it stayed as a SAE30 oil up to 10k miles. You should try Castrol Formula R 10W60 then. I believe it will hold up. Edited April 20, 2005 by Genie47 Link to post Share on other sites More sharing options...
Cookiemonster Neutral Newbie July 22, 2005 Share July 22, 2005 Hi Genie47, Being a new Aveo owner, I really find your post very informative and useful. Just wanna say a big THANK YOU!!! Link to post Share on other sites More sharing options...
Felixpow Neutral Newbie November 24, 2005 Share November 24, 2005 Hi,hi, Genie47 Felix here, new member on board! I'm driving Aveo now, any idea where & which brand/model of performance brake pad suit to my car? Thanks! Link to post Share on other sites More sharing options...
Genie47 1st Gear November 24, 2005 Author Share November 24, 2005 Anyone that fits and is new. I will not give brand names. Link to post Share on other sites More sharing options...
Tann Clutched November 24, 2005 Share November 24, 2005 Genie47 tolong u for name be kind just give ma. Dont base to much on book sometime must turn want and think can turn to be good want. Link to post Share on other sites More sharing options...
Genie47 1st Gear November 24, 2005 Author Share November 24, 2005 I don't want to be blamed for a lemon. Anyway all the major brake pad makers should be OK. Link to post Share on other sites More sharing options...
Maverick88 Neutral Newbie December 7, 2005 Share December 7, 2005 Currently SA mentioned that if after the 1k you can request for fully synthetic and skip the 5k servicing and service at 10k. That means effectively you got 2 free servicing instead of 3. Will you recommend doing this?? Link to post Share on other sites More sharing options...
Genie47 1st Gear December 7, 2005 Author Share December 7, 2005 Its up to you. To me no difference. Link to post Share on other sites More sharing options...
Felixpow Neutral Newbie December 12, 2005 Share December 12, 2005 Hi Genie. Currently I'm using Mobil1 engine oil for my Aveo. Please advise should I use 30wt or 40wt engine oil for 60K service? Link to post Share on other sites More sharing options...
Genie47 1st Gear December 12, 2005 Author Share December 12, 2005 Go for 30wt oil. You will feel reduced component drag definitely. The car is still quite new from the mileage. It can take the oil grade and gain a lot from it. ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes Owners Thread
Swift Owners
Swift Owners
W212 owners, please check-in
Used Car, what STA Inspection grade then can buy?
Kia Cerato GT Line Owners Check In
Daihatsu Owners
Daihatsu Owners
Nic and Cecilia break their pre-nup
