Will_I_Am 2nd Gear March 22, 2005 Share March 22, 2005 Notice that the water level in the reserved water tank keeps decreasing, but quite slowly. I suspect there might be some leakage. This happens after I got my aircon serviced. Could that have cause the leakage due to improper servicing? Appreciate any advice here. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Beanoyip Turbocharged March 22, 2005 Share March 22, 2005 Which water level at which tank are you talking about? So far the only water in the bonnet i know of is the Wiper washer. Link to post Share on other sites More sharing options...
Guyver 1st Gear March 23, 2005 Share March 23, 2005 Yah man.. which water tank? if u are talking about your water bottle reserve tank... and u are drinking from it... of cos water level dropping... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear March 23, 2005 Share March 23, 2005 am sure you are referring to the Coolant reserviour.. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear March 23, 2005 Share March 23, 2005 Are you using only water for the coolant system? Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear March 23, 2005 Author Share March 23, 2005 Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear March 23, 2005 Author Share March 23, 2005 That's right! Anyway, just went to have my aircon checked again. This time they realised that the compressor is faulty and needs to be change. Was told that the magnet in the compressor is losing contact, that's why my aircon not cold under traffic jam driving condition. Sian man - pocket burn big hole! Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear March 23, 2005 Author Share March 23, 2005 Guess I misleaded many by using water ... should use coolant instead No, I have green coolant in my water coolant reservoir and filled over the "FULL" level. Will monitor the water level again. Heard from mechanic that if overfilled pass the FULL level, the excess will be slowly dripped away causing the level drop. Don't know how true it is. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 23, 2005 Share March 23, 2005 Heard from mechanic that if overfilled pass the FULL level, the excess will be slowly dripped away causing the level drop. Don't know how true it is. ======================== Your mech is right. Only top up the reservoir to the "max" line, not higher & only do this when the engine is hot & driven for some time. After a few weeks, if the water level is still dropping, get it checked. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear March 24, 2005 Share March 24, 2005 Do monitor and keep us posted on this. Link to post Share on other sites More sharing options...
Huggable Clutched March 24, 2005 Share March 24, 2005 Don't think it is a big concern, since you mentioned that the water is decreasing slowly. Watch the temp gauge of your car, does it rise to a level that is higher than normal, especially after the aircon servicing? Not advisable to top up the radiator water without adding coolant, as the coolant/water ratio would be affected Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear March 24, 2005 Author Share March 24, 2005 Will do. Thanks bro. Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear March 24, 2005 Author Share March 24, 2005 The temp gauge is as per normal, but I am just concern over the coolant level since I have not had this problem before I got my aircon serviced. Anyway, I also realised that the mech somehow forgot to fill up the coolant level after replacing the coolant valve and the aircon servicing. Not sure if that causes the coolant level to drop drastically. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear March 24, 2005 Share March 24, 2005 Which water level at which tank are you talking about? So far the only water in the bonnet i know of is the Wiper washer. i think he meant the radiator reserve tank... Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 24, 2005 Share March 24, 2005 The temp gauge is as per normal, but I am just concern over the coolant level since I have not had this problem before I got my aircon serviced. Anyway, I also realised that the mech somehow forgot to fill up the coolant level after replacing the coolant valve and the aircon servicing. Not sure if that causes the coolant level to drop drastically. ==================================== Why wud your aircon mech want to touch the cooling system??? I don't see why he has to touch the reservoir or radiator at all??? Aircon system is seperate from cooling system for engine. Link to post Share on other sites More sharing options...
Huggable Clutched March 25, 2005 Share March 25, 2005 Agree... Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 25, 2005 Share March 25, 2005 think is more like existing prob...checked for leakage. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 25, 2005 Share March 25, 2005 think is more like existing prob...checked for leakage. ======================== I think it's time we recommend mazda to Markool. ↡ Advertisement Link to post Share on other sites More sharing options...
Rearing Fish or Koi - advice needed
Coolant level going down
Singapore and Australia tank collided in Shoalwater Bay
McLaren entry level sports car, 570S and its related series
