Secondhand Neutral Newbie March 9, 2005 Share March 9, 2005 Ooo.... I see But by the way... wat's a peltier? ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 9, 2005 Share March 9, 2005 Someone who pelts stones at moving cars. Hahaha Seriously, I guess it's some kind of heat exchange equip for main frames/servers or something like that. Link to post Share on other sites More sharing options...
Guyver 1st Gear March 9, 2005 Share March 9, 2005 1. Some cars come with the heat insulation board behind the hood. it helps to protect paint work on the hood. Is this a neccessity? 2. Some also mentioned that it helps to reduce engine noise. Is this true? 3. What is roughly the market price to install one? Please advise. Thank you. Regards, The insulation is more for sound proofing... anyway... the car's paint work is suppose to withstand high temperature heat.... so doesn't matter if u have it or not. Doesn't really reduce engine noise in my opinion..... If DIY... with normal material... probably $30-$50 can liao... Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie March 9, 2005 Share March 9, 2005 If I catch the bugger who pelts stone at my car, I'm gonna pelt HIM with big huge stones... Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 9, 2005 Share March 9, 2005 Hah. Like that u better not get a Pelter then. Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie March 9, 2005 Share March 9, 2005 Might as well i add liquid nitrogen around the engine. Make it cool faster... Link to post Share on other sites More sharing options...
Maded Neutral Newbie March 9, 2005 Share March 9, 2005 A peltier is a semiconductor-based electronic component that functions as a small heat pump. By applying a low voltage source to a peltier module, one module face will be cooled while the opposite face simultaneously is heated. Link to post Share on other sites More sharing options...
Adrianli Hypersonic March 9, 2005 Share March 9, 2005 Extreme temperature changes will stress ur engine block!!! Link to post Share on other sites More sharing options...
Maded Neutral Newbie March 9, 2005 Share March 9, 2005 .. and break it!! i think if you gave a hot engine block 1 pail of water, it might break... Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie March 9, 2005 Share March 9, 2005 Nah... It won't break... It'll crack... And mind you it'll crack BADLY... Link to post Share on other sites More sharing options...
Maded Neutral Newbie March 9, 2005 Share March 9, 2005 ouch.. Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie March 9, 2005 Share March 9, 2005 Then after cracking so much... Maybe it'll finally break... Link to post Share on other sites More sharing options...
Maded Neutral Newbie March 9, 2005 Share March 9, 2005 but if it cracks... will it still work? i tot crack = broken liao Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie March 9, 2005 Share March 9, 2005 Crack got 2 type... Hairline crack and the super jialat crack... Hairline crack i believe engine still can run... But cannot over-drive... else the crack goes into stage 2.. that is... the super jialat crack. That's when i think all the engine oil will start spilling and all the other stuff comes popping out... Link to post Share on other sites More sharing options...
Maded Neutral Newbie March 9, 2005 Share March 9, 2005 lessons learnt, nitrogen and water cooling for engine block = bad idea!! Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie March 9, 2005 Share March 9, 2005 I was thinking of NOT putting the nitrogen to the engine block... Was thinking of like... direct the heated air to the nitrogen tank... then the cool air go back into the engine... Idea? Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie March 9, 2005 Share March 9, 2005 Maciam like Cold Air Intake... Link to post Share on other sites More sharing options...
Maded Neutral Newbie March 9, 2005 Share March 9, 2005 yeah but then it becomes a running cost thing - much like nitro... i'm looking for fixed cost upgrades to the car which will improve performance... like turbo/super charging... if you play your cards right - lta will approve these mods - on a per model per case basis, or so they say ↡ Advertisement Link to post Share on other sites More sharing options...
Energy Savings / Non Heat up LED Headlights Technology
Intermittent rattling noise, car in ICU
SCHNELL Engine Oil 5W40
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
