Bernielac Neutral Newbie November 27, 2002 Share November 27, 2002 hi all just need some advice on ATF change. heard it might not be good to do a flush. Just drain and refill will suffice. is it true? ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 27, 2002 Share November 27, 2002 Depends on how long has the ATF been left in the tranny and the age of the tranny. What's your mileage on the currently ATF and how old is your tranny? Flushing is usually require when U decide to switch to synthetic ATF, if U change your ATF regularly then a normal drain and fill would be suffice. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie November 27, 2002 Share November 27, 2002 I still have not change yet. Link to post Share on other sites More sharing options...
Vicma Neutral Newbie November 27, 2002 Share November 27, 2002 HI,Tourbobrick. When do change AFT filter,when flushing the tran do they change the filter? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 28, 2002 Share November 28, 2002 U keeping your AMSOIL ATF to make cocktail ah? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 28, 2002 Share November 28, 2002 If the filter is inside the pan then just change and refill whatever ATF that's in the pan will do. If it's an inline filter it's easier, just unplug and change without loosing much ATF. A flush is usually done with a machine and the connection to and from the machine is tapped before the tranny cooler attachment at the radiator area. So most of the time the filter can be changed without a flush if U do not need one. Link to post Share on other sites More sharing options...
Bernielac Neutral Newbie November 28, 2002 Author Share November 28, 2002 hi mine car only 6mths old, a CVT lancer. i know a bit kiasu but just want to protect my fragile tranny.... dun intend to change to any other brand.. sticking to the recommended. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie November 28, 2002 Share November 28, 2002 "bloody lady"!? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 28, 2002 Share November 28, 2002 Oh Mitsubishi, only can use Dexqueen ATF. Do NOT use Dexron or Mercon type! ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Tool to change Spark Plug
X for twitter change request
ATF oil change
ATF oil change
