Madarmour Neutral Newbie November 28, 2002 Share November 28, 2002 The normal ratio of Front and Rear braking are 90:10 90:10!??? Where did you get that? ↡ Advertisement Link to post Share on other sites More sharing options...
Presea 3rd Gear November 28, 2002 Share November 28, 2002 For FWD...I think its closer to 80:20 (F:R). But with hatches, it may be higher ratio for the front...something to do with a different weight distribution. For RWD...if I'm not wrong...it's about 60:40 to 70:30. read it somewhere....may have even come from a computer game Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 28, 2002 Share November 28, 2002 OK. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie November 28, 2002 Share November 28, 2002 From a few web site (chinese wording ) Link to post Share on other sites More sharing options...
Presea 3rd Gear November 28, 2002 Share November 28, 2002 ...maybe I should be a little more specific. Actual brake force for front and rear brakes may not have that much of a difference, with 50:50 to 60:40 ratios more common. But under braking, brake distribution occurs due to the transfer of the car's weight from rear to front, resulting in more brake force required in the front. Cars often have a proportioning valve (or something like that) that increases brake force to the front brakes progressively. This ensures that the front wheels don't lock up too quickly (with too much force applied initially) as well as giving sufficient braking strength as more speed is shed and more weight is transferred forward. That's why the resultant brake distribution is more front biased. read this somewhere online.....but can't seem to find the article now. My internet connection at work is so slow..... cheers Link to post Share on other sites More sharing options...
Lightspeed Clutched November 28, 2002 Share November 28, 2002 $700 including installation? I think you can get used disc from scrapyard. Then get a workshop to install for you. I would never consider a used rotor. IMO, these stuffs are too important to go for 2nd hands. Too much is at stake here. Just my $0.02. true true... but what to do? there are just no new drum to brake conversion kits out there for our cars Link to post Share on other sites More sharing options...
Wymun Neutral Newbie November 28, 2002 Share November 28, 2002 Thanks for the pointer - I stand corrected... Actually, when we asked the last driver why he couldn't stop in time (cos we weren't really going very fast), his verbatim comments was "I don't know lah...I think in the morning I never pump my brakes enough"... Now what do you make of that?? In any case, I already got back my car with new bumper and all - also car was polished and it looks spanking new!! In fact, it still smells of fresh paint... Link to post Share on other sites More sharing options...
Huggable Clutched November 28, 2002 Share November 28, 2002 Yeah man, you have a point there. Before this I always thought that the rotors are "indestructable" and can last a lifetime. Just need to get good brake pads! I did considered getting the disc drilled, for about $200. But decided against it, coz if anything goes wrong, that's a high price to pay! I would never consider a used rotor. IMO, these stuffs are too important to go for 2nd hands. Too much is at stake here. Just my $0.02. Link to post Share on other sites More sharing options...
Huggable Clutched November 28, 2002 Share November 28, 2002 >but what to do? there are just no new drum to brake conversion kits out there for our cars Can't you install the MX's rear disc to your car? During a C&C workshop for Kia cars, I asked the engineering adviser if I could buy the rear disc of the Kia Mentor, and the entire ABS system, to install in my car. He just refused to, saying that it won't fit! For the record, C&C market the Mentor with ABS, all wheel-disc brakes, and twin airbags. But the Sephia gets rear drums, no ABS and no airbags! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 28, 2002 Share November 28, 2002 Thanks for your explanation. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 28, 2002 Share November 28, 2002 If you really have to get the 2nd hand one, please check carefully. At least 3 times! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 28, 2002 Share November 28, 2002 >>his verbatim comments was "I don't know lah...I think in the morning I never pump my brakes enough"... Non-commital answer mah. Remember, it's always someone else or the car's fault, not mine! >>his verbatim comments was "I don't know lah...I think in the morning I never pump my brakes enough"... Hoah..................that was FAST! Great! Link to post Share on other sites More sharing options...
Lightspeed Clutched November 28, 2002 Share November 28, 2002 I think they have to do some alterations to the arms as well? not sure ... Link to post Share on other sites More sharing options...
Lightspeed Clutched November 28, 2002 Share November 28, 2002 anyway I'm not willing to spend so much on the conversion Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 28, 2002 Share November 28, 2002 >>Before this I always thought that the rotors are "indestructable" and can last a lifetime. I had the same impression too, until my rotors wore out in 2 years. Over this time, I've used 2 sets of pads. >>I did considered getting the disc drilled Unless the machinist is damn skilled, getting the rotors drilled is a no-no. IMO better get a slotted rather than X-drilled rotors. Drilled ones are subjected to micro-cracks around the holes. Anyway, you can get a pair of slotted rotors for less than $300! Brembo Max was selling for less than $200 a set! So why bother! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 29, 2002 Share November 29, 2002 Next car lor................... ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Handbrake Lever up, does the brake light comes on?
