Idemitsu Honda Oil
Chousei
Any oil is good. Do you know that your Honda engine is spec'd to run 20wt oil? Since you bought the oil already. Use the 15W40 for your 1k change. Then use the 10W30 for the next change (I think it is 5k). Then finally for the 10k oil change, get yourself a 20wt oil. Most easily available is Royal Purple 5W20. Check out Zakuii from this forum. He is using the 5W20. Redz uses the RP 10W30 because he frequently travels up the NSH. Choose your oil carefully for the application you use your car for.
Please note that using 15W40 will make your Honda consume a lot of gas. You will have poor FC. Expect it.
What Honda are you driving?
well said!! yeah ..i'm on 10W30. even after almost reaching 10k usage, i still able to maintain my 11-12km/l om my 1.7L stream [thumbsup] . i tot the FC will drop as the mileage is close to 10k....but, hey...it's good. dun feel sluggish too. wanted to try 5W20....but bought 10W30 for my next 30k km servicing sometime this or next week.
bro.. ur FC so good ah. think i will switch to city auto for my next svc.. which is 70k. can bring own oil there. then hopefully, my FC can go better than 14... achieve in my stock 14 inch rims n tyres.. now 15 liao. like FC gonna suffer. [:|][:|]
ah, genie, genie....
my 323 also wanna change oil leh... now on shell helix ultra on per 10k service. the wt shld be 10W30... wat do u think i shld change ah ?
i thot of getting better FC, tho i quite freq NSH... but i dun think i hit 4k RPM at constant periods.
i heard from normally aspirated got this brand call chemlube. he said this oil can last for 20k if can take the risk ? [shocked][shocked][shocked] wats ur comments on this oil ?
coz i think 323 needs 3 litres for changing... seems like this chemlube one not bad...
Sure can last but can your oil filter last until 20k ornot? tongue.gif By 10k, might be clogged already. Tell you what lah, use the 10W30 for 15-16k. That is 10k miles. Very shiok already. smile.gif
[LEV for Honda stands for Low End VTEC.....
No offence....just a joke only. tongue.gif[/reply]
Hey! you want to start a war here??!!!! [rifle] arghhhhh......... honda bros, time for smoke out!!!......... [pirate]
BP Visco 7000 is ACEA A3 rated 0W40. See if Forklift brings it in. Maybe can get for 78. The Astra H needs 40wt A3 oil issit? Can use 30wt ornot? If can, use Castrol SLX-A3 0W30.
Forklift Enterprises. Use the search. Address is somewhere in the archives. Do you know that BP owns Castrol and the BP Visco 7000 can be otherwise known as Castrol SLX-A3 0W40 laugh.gif.
light footed nia... [nod]
