Aikshin Neutral Newbie February 6, 2005 Share February 6, 2005 hi all, need to ask how do u guys apply the swirl remover ? is it the usual up and down strokes or in a circular motion to remove the swirls ? is it also dun apply too much in case it gets haze ? cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Assassin Clutched February 7, 2005 Share February 7, 2005 Hi aikshin, There are different ways of applying it, there are already instructions on the back of the bottle. This is what I normally do: clean the affected area, make sure there are no other loose dirt around squeeze a bit of the 3M SMR onto your finger and rub it into the affected area in small circular motions, try to rub across the scratch/swirl marks rather than along it leave for about 30 seconds before buffing with a cotton or microfibre cloth repeat process again until the swirl/scratch marks are less prominent apply some sealant over the area to protect it N.B: You cannot totally remove the scratch/swirl marks, you can only make it look less obvious. Hope this helps. Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Mark X - Maintenance and Servicing
Scratch remover don't work
Types Of Car Odor Remover : Fact Or Myth?
Mark Dumas and his polar bear
2014 Toyota Mark X
2014 Toyota Mark X
Getting Rim Chrome or Apply Chrome Powder
Lexus GS450H Mark Levinson Speakers Foam Repair
Apply own car loan
Apply own car loan
