Kimo Neutral Newbie November 26, 2005 Share November 26, 2005 They are crap ↡ Advertisement Link to post Share on other sites More sharing options...
Yc86 Clutched November 26, 2005 Share November 26, 2005 agreed.. Link to post Share on other sites More sharing options...
Essentiale Neutral Newbie November 27, 2005 Share November 27, 2005 good post a passionate one too.... must have pissed you off when the air chargers were useless after installation.. Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie December 8, 2005 Share December 8, 2005 I pay much less than that lah! bought second hand from a ESI owner when the MY dealer didn't know how to install the wiring & always blow the fuse Bro i think u got to wire up with a relay n a fuse lor If still fuse blow Then your wiring maybe error lor Or blower ( Up the lorry liao ) Link to post Share on other sites More sharing options...
Mizarahi Clutched December 20, 2005 Share December 20, 2005 Some brother installed such blower for me from the CAI. I think the ADM priciple is to induced more cold air and not the so called supercharging. Agreed with all bros here that to gain hp you need pressure. So the ADM definitely snake oil on this aspect. I went for this setup istead of open pod bec' worry that low end suffer. So improved CAI is better. So far quite happy with it. Butt feel is 20kmh to 60kmh can be quickly attained. Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie December 21, 2005 Share December 21, 2005 ADM snake oil hehehe actally all his stuff we could DIY if u r smart enough like the so call ADM controller for the blower i diy the same liao Snake Oil Snake Oil Sg got alot of Snake Oil His mod Car go street race like never c him win before lar N stick so many ADM sticker Link to post Share on other sites More sharing options...
Genie47 1st Gear December 22, 2005 Share December 22, 2005 Because of the laws against hardcore car engine modding, people are desperate and will grab any "performance cure" they see. That is why snake oils rank so high on the minds of Singaporean car owners and not so much elsewhere. It is the combination of this and "extreme car poverty" . Show me a car owner and most likely he is already a poor man. Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie December 22, 2005 Share December 22, 2005 Agree And thanks for the Meetup ( secret ) Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 23, 2005 Share December 23, 2005 Bro i think u got to wire up with a relay n a fuse lor If still fuse blow Then your wiring maybe error lor Or blower ( Up the lorry liao ) When I meetup with the seller, and after I look at the wiring, immediately knows that the wiring is done wrongly liao, that's why I get it at very good price me study electronics/electrical last time lah Link to post Share on other sites More sharing options...
BlueSi Neutral Newbie December 27, 2005 Share December 27, 2005 I have a question for you guys here about these air chargers. Do these units come with a feedback loop to ur ECU to give your car more gas when "boosting" so that you wont run too lean? Link to post Share on other sites More sharing options...
Kanr 1st Gear December 27, 2005 Share December 27, 2005 I think it should be !!! Link to post Share on other sites More sharing options...
Rascal407 Clutched December 27, 2005 Share December 27, 2005 the adm air charger do not come with any feedback loop.it is the maf that detect the amount of air going in and the o2 sensor that feedback the amount of gas going out to the ecu Link to post Share on other sites More sharing options...
BlueSi Neutral Newbie December 27, 2005 Share December 27, 2005 Wats the range of fuel control a stock ECU can learn? Are they enough to handle what this unit is throwing at it? I think its quite risky to let the stock ECU handle AF with any form of force induction, but I guess one wont know until they put their car on a dyno, run it while checking the AF mixture. Not fun when u run lean and start burning up piston rings. Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 27, 2005 Share December 27, 2005 this air charger will acheive less that 1/4 psi of "boost" and that is definately within the capability of the stock ECU to give that very slight increase of fuel no worry of running lean or maxing out the fuel injectors Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie December 30, 2005 Share December 30, 2005 thats gd i diy my blower n the wiring Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie December 30, 2005 Share December 30, 2005 Forget about letting your ECU relearn because it does and doesn't. It does when MAF detects higher AF ratio and hence ECU ups the fuel mixture. It doesn't because the increase of fuel mixture is not necessary as all stock ECU maps have a very rich mixture and hence your car would feel a bit torquey on low end but eventually dies off after a while. If you want a car that goes from 0-80kph very quickly and get smoked after that, ADM charger is the way to go. Link to post Share on other sites More sharing options...
Noregretforever Neutral Newbie January 1, 2006 Share January 1, 2006 Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie January 27, 2006 Share January 27, 2006 I diy 3 blower liao hehe ↡ Advertisement Link to post Share on other sites More sharing options...
DIY ADM aircharger Ver2 + Simota Carbon filter
ADM Aircharger
ADM Aircharger
ADM New Rated 3x Aircharger
