Stevegring Neutral Newbie January 22, 2005 Author Share January 22, 2005 Thanks a lot, mate! I have done a lot of research and found that no car of the same model sells cheaper than I paid. By the way, what kind of engine oil are you using? Please advice. ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 22, 2005 Share January 22, 2005 (edited) I used to service my car at Stamford Tyre, so using Havoline 20W50 since I got my car. Now I service my car at my usual mechanic shop - recommended by my Dad. Its actually a spare parts shops at Yew Tee area, but can also do parts repalcement/repair such as shock absorber, timing belt, etc. I plan to use Mobil Delvac MX 15W40 in my next oil change, as per Genie47's advise. You can check out the older thread on the discussion on Heavy Duty Engine Oil (HDEO), which is better for old cars. Edited January 22, 2005 by Octopus Link to post Share on other sites More sharing options...
Genie47 1st Gear January 22, 2005 Share January 22, 2005 This car uses the same carburetted 2E engine that some sleeper Starlets have. Imagine 80HP pushing a 700kg chassis. But on a G6-G7 chassis, pretty much like a bus. OK about this engine. Get the carburetor serviced. Clean out the gum and junk. It is an Aisan with an autochoke which needs a feed from the coolant. Tune the carburetor when you are using RON92 gas. At least you can use cheaper fuel this way. Next thing to change is the ignition wires. Ignition wires do wear out and they have a lifespan of 10yrs. The dampers should be next and watch out for the CV joints. Since it is an old car, they may go anytime. Listen for the tell tale clacking sound as you turn. Also look for damage on engine mounts. They too last only 10yrs barring accidents. Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 23, 2005 Share January 23, 2005 recently discovered that mine came with carburetted 3E engine. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 23, 2005 Share January 23, 2005 Great low end torque but you don't much on the high end. Basically longer stroke. Good enough for you. Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 23, 2005 Share January 23, 2005 that's very true! usually when starting off from traffic light, i can pick up better than the average vehicle. of course, being a manual car helps. unfortunately, the highest speed i've ever travelled so far is 130 km/h. speed exceeding 130 km/h seems to be increasing very slow. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 23, 2005 Share January 23, 2005 (edited) That is the drawback of having a longer stroke. So technically, you are driving a Tercel. Edited January 23, 2005 by Genie47 Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 24, 2005 Share January 24, 2005 Yap, looks like the previous owner had transplant the engine from a Tercel. But I do not know what a Tercel looks like. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 24, 2005 Share January 24, 2005 Go to Cardomain to see. Basically it is a cheaper Corolla. When it first came out, it is called the Corolla Tercel much like what the Altis is now called in Singapore as Corolla Altis. Knowing Toyota, they will drop the Corolla name and make the car unique and distinct from the Corolla. That is how they sell cars. Make people think it is a Corolla while it is on its way from being anything but a Corolla. Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 24, 2005 Share January 24, 2005 I see....thanks! Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 25, 2005 Share January 25, 2005 (edited) I just bought it and have yet to receive the car. I am interested in getting an operator manual and the repair manual. Where can I get them? Hi Stevegring, Have you got your car already? Edited January 25, 2005 by Octopus Link to post Share on other sites More sharing options...
Stevegring Neutral Newbie January 25, 2005 Author Share January 25, 2005 Hey mate! I will be getting it tomorrow. So excited about it! Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 25, 2005 Share January 25, 2005 That's good! Do keep me updated on your ride's FC, maintenance, etc. Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie January 25, 2005 Share January 25, 2005 I wish to know about it's specification or get it's repair manual, but to no success. Anyone knows where I can obtain them? Please advice! You can try Autobac for the "Toyota Corolla : service and repair manual". Saw it when Autobac was still operating at Paya Lebar. Link to post Share on other sites More sharing options...
Stevegring Neutral Newbie January 25, 2005 Author Share January 25, 2005 But I do not know my car's technical specification. Do you have some knowledge about your car's specs? Link to post Share on other sites More sharing options...
Stevegring Neutral Newbie January 25, 2005 Author Share January 25, 2005 DO you know any book shop selling repair manual? Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 25, 2005 Share January 25, 2005 My knowledge in this area is very limited. What type of technical specifications are you looking for? If its things like rims specification for such car, replacement parts, etc. I'm sure the vendor/mechanic may be able to advise. Or perhaps other fellow MCF'er here could help you? Link to post Share on other sites More sharing options...
Stevegring Neutral Newbie January 25, 2005 Author Share January 25, 2005 Things like air pressure for the tyre, what is the most suitable engine oil for this model and so forth.. ↡ Advertisement Link to post Share on other sites More sharing options...
New 2015 Toyota Alphard and Vellfire
2026 8th Generation Lexus ES
Toyota Corolla Cross
Toyota Land Cruiser Mini
