Kelpie 2nd Gear January 20, 2005 Share January 20, 2005 1. I wonder whether there is a specific weight ratio between Rims and Tyres? For example, a 7 kg rim should be matched by a tyre weight of not more than 7kg. 3. By looking at magzines, it also seems to suggest that the ideal weight ratio between rim and inch should be: (Rim size -10)/weight of rim). For example, (17-10/7)=1. Hence if a 17" rim is 8kg is overweight by 1 kg. What do you guys think? Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Mtoh Neutral Newbie January 21, 2005 Share January 21, 2005 where u get this formula from ? All i know is the lighter the better..... hehehe Link to post Share on other sites More sharing options...
Kelpie 2nd Gear January 21, 2005 Author Share January 21, 2005 Hi there, 1. My own formula..hehehe. 2. When I browsed through the car magazines, most of the reputable brands have 17" rims weighted around 7kg. This led me to derive the formula, there must be some basis for it if the manufacturers are making 17" rims at 7 kg each. Regards, Link to post Share on other sites More sharing options...
Robertoon Neutral Newbie January 21, 2005 Share January 21, 2005 never known of any formula. Take note that all wheels are design to a maximum load index. That is more important not to overload the wheels. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear January 21, 2005 Author Share January 21, 2005 A friend of mine brought his own bathroom scale to measure his stock rims and tyres against the new set rims and tyres, making sure the new one is not heavier. I probably will bring mine to ensure too....hehehe. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Formula 1 (2017)
Formula 1 (2017)
Quad Light Bulb Size
New Study Explores Connection Between The Size Of Your Manhood And Sports Cars
Tire size not available in Singapore, how?
Calculation of "bone weight" (骨重)
Niki Lauda, Austrian Formula 1 legend, dies at 70
A new tire size calculator
Formula One 2019
Formula One 2019
