Multi 3rd Gear January 17, 2005 Share January 17, 2005 (edited) Hi all, Just wondering, does changing a lowered temp radiator thermostat will improve performance? Be it FC or power...please advice, thank you. Edited January 17, 2005 by Multi ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear January 17, 2005 Share January 17, 2005 Overcooling will have its own set of problems. I read it in a book on automotive cooling in the library before. Can't remember what damage occurs. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched January 17, 2005 Share January 17, 2005 Can lower temp affect the engine oil vercosity resulting less lubrication? Link to post Share on other sites More sharing options...
Genie47 1st Gear January 17, 2005 Share January 17, 2005 Actually no. If coolant system is too efficient removing too much heat, what will happen is that the ECU might compensate by giving the engine more gas to burn! Yikes! Remember, ECU will work to protect the engine. I must get hold of that book. Overcooling will damage pistons just as overheating will too. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched January 17, 2005 Share January 17, 2005 no wonder newer cars fuel consumption higher.... Link to post Share on other sites More sharing options...
Genie47 1st Gear January 17, 2005 Share January 17, 2005 No lah! It is not that. Messing around with the coolant thermostat will bring about strange reactions from the ECU. Quite like the IATS hack. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched January 17, 2005 Share January 17, 2005 IATS hack? issit those adding resistors to the sensor output? Link to post Share on other sites More sharing options...
Genie47 1st Gear January 17, 2005 Share January 17, 2005 Yes resistor to Intake Air Temperature Sensor (IATS). Link to post Share on other sites More sharing options...
Normal_aspirated Clutched January 17, 2005 Share January 17, 2005 (edited) thks[nod] Edited January 17, 2005 by Normal_aspirated Link to post Share on other sites More sharing options...
Apollo 1st Gear January 17, 2005 Share January 17, 2005 dun think so... cos the replacement thermos r usually operating at 4 degC lower than stock, which is sure hell not gg to make much of a difference. what the thermo does is act as a switch for the radiator fan to operate, and nothing more. the ECU operates to pump more gas into the engine when the result it recieves fr the intake O2 sensor, lamba sensor, etc does not map into the richer scale of the flammability diagram. ie there is too much air and that makes the premixed air-fuel too lean. so the ECU adjust itself by adding more fuel into the premixing to ensure more richer mix. this happens when superchargers are used to try and reduce the rich mix to the stoichiometrical line. the ECU thru closed looping learns and adjust. and if u look into the FC data for cars, the results fr temperate countries are usually much better than those locally, reason... local climate is hotter. and there is a way to check if hotter engine makes better cars, just remove the fuse for the radiator so it would be operating... yeah? (WWE disclaimer; do try this at home.) Link to post Share on other sites More sharing options...
Genie47 1st Gear January 17, 2005 Share January 17, 2005 Actually what I mean is operating way below programmed norms. 4 deg C is not much. Link to post Share on other sites More sharing options...
Sky8807 1st Gear January 18, 2005 Share January 18, 2005 what the thermo does is act as a switch for the radiator fan to operate, and nothing more. Agree with that. Link to post Share on other sites More sharing options...
Multi 3rd Gear January 18, 2005 Author Share January 18, 2005 I thought the thermostat is to release the water flow when the preset temp is reach. So, if we change to a lower temp thermostat, maybe 20 degree lower, the frequency of flow will be more thus the engine will not be as hot as before and thus improve some performance...correct me if I'm wrong... Link to post Share on other sites More sharing options...
Apollo 1st Gear January 18, 2005 Share January 18, 2005 flow rate of ur coolant water is based on the water pump which is in proportion with ur timing belt. more flow does not equate to better cooling. a lot depends on the coolant used, the radiator, radiator fins, dirt accumulating on the radiator, water pump condition, engine oil temp, etc. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 18, 2005 Share January 18, 2005 (edited) OK finally got the book. Apparently overcooling is bad even at 4 deg C difference. True enough the thermostat controls the fan but it also controls the flow of coolant to the radiator via a valve. At the start up cycle, the valve is shut when the coolant is cold. So the engine builds up heat and then the thermostat kicks the fan to move and the valve to open to allow the coolant to flow to the radiator. Now in the case of overcooling, the engine's real life blood which is the engine oil itself will become sludgy. Acid will also build up in the oil shortening its life. Because the oil does not reach operating temperature, the engine becomes sluggish and poor fuel economy will result. So much for temperate climates getting better FC than our local cars. With an engine operating at optimum temperature, the deciding factor for FC is the intake air temperature and not the ambient temperature's effect on the coolant. The other effect of temperate climate is the heater's performance. With the thermostat, you will get the cabin heated sooner because the coolant is does not lose its heat too fast. Very important for them. The other result of the fan running frequently is that the fan's life is also shorten with the possibility to taking out another critical component out of a good working engine sooner than expected. So in summary, Normally_aspirated's question if the coolant making the oil more viscous than it is supposed to be is correct. Not just more viscous. An acidified mixture too! Which means that replacement thermostats are best to be as close as possible to the stock ones for optimum operation. Edited January 18, 2005 by Genie47 Link to post Share on other sites More sharing options...
Genie47 1st Gear January 18, 2005 Share January 18, 2005 (edited) OK lower coolant temperatures will not increase performance. Read the post above this. So how to improve performance. Reach operating temperature faster! Interestingly, engine oil warms up much faster when driven lightly between 1500-2000RPM as compared to idling. So all those guys taking a smoke and letting your engine idle are doing yourselves a bad favor by burning more petrol and getting nowhere. Apparently, if it is at idle, the engine is not shearing the hydrodynamic properties of the engine oil. Shearing will generate heat. But when you start moving your car, you are subjecting the engine to a load and thus need higher RPM which in turn shear the oil generating heat! This also explains why on the NSH going up to KL and beyond at speeds in excess of 120kph or more, your engine has higher temperatures! Sometimes in excess of 110 deg C! So your quest for lower cooling temperatures is flawed and what you should be asking for is more efficient cooling! Buy that bottle of Redline Waterwetter! Edited January 18, 2005 by Genie47 Link to post Share on other sites More sharing options...
Genie47 1st Gear January 18, 2005 Share January 18, 2005 (edited) I've read up more. Apparently, many are in favor of very hot engines but the materials used in todays engines just can't do it. Explains the obsession by a maker in developing ceramic engines. Imagine an engine that does not require coolant! Somehow, they figured out that the internal combustion engine is most efficient when extremely hot. So hot that after the start up, spark plugs are not needed! Got read up on the theory about this. Edited January 18, 2005 by Genie47 Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 18, 2005 Share January 18, 2005 The on-board computer, if it continues to recieve coolant temp voltage reading below the default setting, it will continue to increase the fuel trim cycle - that means it will trigger the fuel injectors to open for a longer period resulting in more fuel being injected into the system. For some model of VW, the cooling system has two coolant temp sensors - one for the lower limits and the other for high limits. There is many cases of mechanics accidently switching the wire harness resulting in the car always running on rich on fuel ↡ Advertisement Link to post Share on other sites More sharing options...
DTC P0597 Thermostat heater control system open circuit
Music Concerts
Music Concerts
Using blower to dry car
2023 Mercedes-AMG C63 S E Performance
Consolidation of useless modification (Performance parts)
Goodyear Eagle F1 Asymmetric 5
CPU chip - What are you using? Intel or AMD?
