Vit4wd 1st Gear February 27, 2005 Share February 27, 2005 Now already AFTER CNY. So when can we see your nice picture? ↡ Advertisement Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear February 28, 2005 Share February 28, 2005 haha.... almost forgot about that.. Link to post Share on other sites More sharing options...
Ruggles Neutral Newbie January 20, 2006 Share January 20, 2006 hi its me again, wan yr opinion on engine oil issue. getting 1.3 wira OPC. as i anticipate very little use of the car so the run in period will be rather long & also car most of the time will be parked. shld i juz go w the original mineral oil e car is delivered with till 5K then chg to syn oil or shld i upon delivery chg to syn oil so even when parked for long time the syn oil is still (hopefully) coating the engine parts & even at 1st start engine inner surfaces is protected? or shld i go somewhere in between like use car more regularly then chg to syn at mayb 1K? my concern is engine protection during run in period. appreciate all opinions, Thks Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 20, 2006 Share January 20, 2006 You should use the mineral oil as per delivered and maybe change to Syn upon 1K delivery. I was using 10W40 for almost 2 years. Have changed to 5W30 recently and realise my FC is improving. Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie January 20, 2006 Share January 20, 2006 Dear proton kakis, juz bought a 7yrs old wira would like to know will wira consume engine oil?? planning to use fully syn for my wira. What's the mileage on your odometer? Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie January 20, 2006 Share January 20, 2006 Mobil 1? Link to post Share on other sites More sharing options...
Ruggles Neutral Newbie January 20, 2006 Share January 20, 2006 so yr opinion is juz drive w the mineral oil till 1K then chg to syn. but my 1k may be longer then 3 mths if based on OPC hrs of usage, so i guess u are suggesting i drive more initially to quicken the run in, hit 1K chg to syn then juz go on normal OPC usage? thks Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 20, 2006 Share January 20, 2006 yes sir... thanks to Linus... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 20, 2006 Share January 20, 2006 no need to rush into clocking the 1000km... Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie January 20, 2006 Share January 20, 2006 Just out of curiousity, will you be trying out 10W-30? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 20, 2006 Share January 20, 2006 dun think so.... ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
