Academia Neutral Newbie January 10, 2005 Share January 10, 2005 Hi there, is it common to top up the radator water every 3 days or so. Morning, I can see a pool of water ynderneath. My car is a Merc 200E. ↡ Advertisement Link to post Share on other sites More sharing options...
Protege 1st Gear January 10, 2005 Share January 10, 2005 I think your radiator is leaking. Topping every 3 days is a little too much. I think once a few months may be normal. Better send to mechanic and have a look. You dun want your engine to overheat. Link to post Share on other sites More sharing options...
Francis Neutral Newbie January 10, 2005 Share January 10, 2005 Hi Protege, This is Francis, You are right, radiator topping up every 3 days is a sign of leaks definitely. Link to post Share on other sites More sharing options...
Julian Clutched January 10, 2005 Share January 10, 2005 got the same problem too... mine is the sensor switch not working Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 10, 2005 Share January 10, 2005 Definitely uncommon. I'm driving a COE car, and radiator water only need to be topped up a little bit every 2 months or so. ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator Cap
Radiator Cap
Family of three electrocuted to death at Taman Jurong
