E21s Neutral Newbie November 12, 2002 Share November 12, 2002 Actually, based on law of physics, frictional force is dependent on the the weight of the car and the coefficient of friction. So the more heavy the car, the more frictional force exist between the tire and the road. Although I would say the momentum is greater. ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 12, 2002 Share November 12, 2002 Bro if Chris offer to give U free mods for using your stream as a test bed I suggest let him try. Alternatively do some intentional ebrakes to build up confidence of your Stream brakes. My brick had long brake pedal travel and a tad of sponginess then hard pedal feel, even after s/s brake hose and DOT 5.1. It's inherent but the brake feel did improve after the hoses and semi-met pads. (Bendix and Mintex were the brands I tried). What tires U running on? Better traction tires will help too. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 13, 2002 Share November 13, 2002 >> Actually, based on law of physics, frictional force is dependent on the the weight of the car and the coefficient of friction. So the more heavy the car, the more frictional force exist between the tire and the road. Although I would say the momentum is greater. The main frictional generators will be the brakes and friction increases with the amount of force applied to the brakes. The frictional force due to the additional weight in the car has less play once the car is put on wheels. So the momentum gain from the additional weight far exceeds the frictional gain from it. Link to post Share on other sites More sharing options...
Blue Neutral Newbie November 13, 2002 Share November 13, 2002 (edited) How to adjust ? Can try looking for the linkage/plunger at the other end of the brake pedal below the stering wheel, should have an adjusting screw with a locknut. Edited November 13, 2002 by Blue Link to post Share on other sites More sharing options...
Blue Neutral Newbie November 13, 2002 Share November 13, 2002 The main frictional generators will be the brakes and friction increases with the amount of force applied to the brakes. The frictional force due to the additional weight in the car has less play once the car is put on wheels. So the momentum gain from the additional weight far exceeds the frictional gain from it. Well said Link to post Share on other sites More sharing options...
E21s Neutral Newbie November 13, 2002 Share November 13, 2002 Please refer to the following article on the physics of braking and friction especially the last few paragraphs and sentences. http://www.teamscr.com/grmbrakes.htm Link to post Share on other sites More sharing options...
Kotila Clutched November 14, 2002 Share November 14, 2002 Me driving Stream 1.7L. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 14, 2002 Share November 14, 2002 Ah bro, you're right! New things learnt everyday! Sure doesn't feel the car can stop at a shorter distance under full load, though. Maybe it's just the feeling. Hmmmmmm, need to do it objectively and see. Cheers! Link to post Share on other sites More sharing options...
E21s Neutral Newbie November 14, 2002 Share November 14, 2002 U are welcome. Just remember Frictional Force = u x N where u = coefficient of friction while N = downward force. I'm sure me got new things to learn from u too. Link to post Share on other sites More sharing options...
French_porn Neutral Newbie November 17, 2002 Share November 17, 2002 Sorry. What is BVO? Link to post Share on other sites More sharing options...
Assassin Clutched November 17, 2002 Share November 17, 2002 BVO Automotive Blk 15 Sin Ming Industrial Estate #01-111 Singapore 575673 Tel: 6455 1566 They do quite a number of Beemers there. Link to post Share on other sites More sharing options...
French_porn Neutral Newbie November 18, 2002 Share November 18, 2002 oh i c Link to post Share on other sites More sharing options...
Assassin Clutched November 18, 2002 Share November 18, 2002 No worries. Link to post Share on other sites More sharing options...
Ek3stage 1st Gear December 17, 2002 Share December 17, 2002 u want firmer braking add a brake stopper ...cusco shld have one for stream also. the steel braided hoses DOES nothing to everyday driving...even occassional hard braking also no effect....dont waste $$. If you feel it means something wrong with the original hoses and not because got the new hoses... ↡ Advertisement Link to post Share on other sites More sharing options...
Battery for Honda Vezel
Takata airbag recall
