Diesel 1st Gear November 14, 2002 Author Share November 14, 2002 Called up a couple of distributors for Tein, only 1 was kind enuff to entertain me, the rest service attitude quite bad Next shipment of S-Tech(medium) coming in mid-Dec, for soft type (which i requested) have to order separately coz they only bring in the medium (due to demand & popularity i guess). Anyone can enlighten me on the diff between the medium & soft? The soft one should be stiffer than stock right? According to the specs, the spring free length for medium is longer than the soft, how cum huh? I'm going for stiffer than stock without sacrificing too much comfort... I'm using KYB shocks now, will it affect the life-span of my shocks should i get the soft type? ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 14, 2002 Share November 14, 2002 To compare stiffness of springs have to get the spring rates...hard to tell from the model or brand unless have prior experience Are your KYBs aftermarket gas shocks or stock ones? Link to post Share on other sites More sharing options...
Diesel 1st Gear November 14, 2002 Author Share November 14, 2002 My KYB are after-market ones... KYB "Super" in Red & White box... The Tein supplier kept persuading me to get the medium type (out of convenience on his part when ordering perhaps?), saying the soft ones "cannot make it", have to drive like Ah Pek I personally feel that the soft type is suffient for my liking, stiffer than stock, not too hard. I dun do hard cornerings, but prefers better handling-in terms of reduced bodyroll, no nose-dive when E-braking, rear dipping when accelerating hard... Will be paying them a visit tomorrow after work... to check out the springs personally... if confirm, also have to wait 3 weeks for the soft type, or till mid-Dec where their medium stock comes in.... How? Soft or Medium??? To be frank i'm slightly more inclined to the soft one... but this question of how come not many ppl use that (which is why they dun bring in the soft stock) puts me in dilemma... For info i'm driving a '92 Ah Pek corolla 1.3M... Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie November 14, 2002 Share November 14, 2002 Autoplus no longer dealing with Eibach liow. Only HotWheels has. BTW, care to share how is KYB? Link to post Share on other sites More sharing options...
Diesel 1st Gear November 14, 2002 Author Share November 14, 2002 Love it!!! I think coz my stock springs had worn off, can feel the shocks in action more often... especially when going over humps, the ascend & descend is gradually, doesn't give me the "pop-up" feeling... but if going over humps over 40km/h.... then bottom out liao... So now replacing springs have to choose carefully, dun wanna end up in teeth-chattering ride everyday!!! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 14, 2002 Share November 14, 2002 For the soft springs do they have lowering effects as well? If the spring rates are soft but not softer than stock then I say take them. You'll sacrifice the handling ability only slightly (probably at the limits rather) when U choose the soft over the mediums. I had Eibach springs with Bilstein shocks and those were really hard stuff. The bilsteins were hard plus the Eibachs (half the height of my stock springs which were already stiff), harder and harsher than MRT but when it comes to corner and slalom style driving So it boils down to your driving habits, do U luv taking your tires to traction limits? Screeeeeecccccchhhhhh Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie November 14, 2002 Share November 14, 2002 May I know how much for yr Eibach Prokit? Link to post Share on other sites More sharing options...
Diesel 1st Gear November 15, 2002 Author Share November 15, 2002 (edited) The lowering is the same for all grades (15-26mm). SOFT Front: 3.2kgf/mm Rear : 1.4-2.5kgf/mm Spring Free Length : 236(F) 322® MEDIUM Front: 2.5-4.0kgf/mm Rear : 1.4-3.1kgf/mm Spring Free Length : 250(F) 311® Just wondering how come the medium grade spring rate has a range for the front spring rate? The soft grade spring rate falls just in between the range for the medium grade. I'm a "soft" driver lah, no hard cornerings or slalom-style driving... Anyway, my tyres are also not performance type.. Aspec dB, comfort & quiet! Edited November 15, 2002 by Diesel Link to post Share on other sites More sharing options...
Diesel 1st Gear November 15, 2002 Author Share November 15, 2002 I have yet got the quote from Hotwheels, they should be around the region of $400+-... Try www.hotwheels.com.sg for their contact. Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie November 15, 2002 Share November 15, 2002 Thanks for the info. I am looking for a set of shocks to replace my stock shocks. Considering between KYB and Koni. Link to post Share on other sites More sharing options...
Diesel 1st Gear November 15, 2002 Author Share November 15, 2002 I heard konis are real stiff... so choose depending on ur driving likes I got my KYBs at abt 75/pc... i think now should be cheaper Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie November 15, 2002 Share November 15, 2002 Hear the same thing too. That's why I am keen to explore KYB. Have you heard of KYB New SR (bright Blue)? I read in the Mit forum that this is very difficult to get in Singapore. Can you share where you got your KYB Super? Thanks in advance. Link to post Share on other sites More sharing options...
Diesel 1st Gear November 15, 2002 Author Share November 15, 2002 There might be newer KYB models. How come difficult to get in singapore? issit the top-of-the-range shocks for KYB? I got mine at OSK Trading in AMK Autopoint Level 5... unit no. forgot liao... but i knoe the Towkay name Ah Kiat, drives a maroon Corona CD... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 15, 2002 Share November 15, 2002 Koni Yellows are very firm, even at the softest setting. Ask Richard. BTW, he has a set of Bilsteins sitting in his office now! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie November 15, 2002 Share November 15, 2002 But I dun think I can use his set lah. Otherwise will buy from him. Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie November 15, 2002 Share November 15, 2002 Thanks for the info. Will check it out when have the time.... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 15, 2002 Share November 15, 2002 No you can't use his set and he DEFINITELY will not sell it to you. He's been waiting for almost a year for it.................. Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie November 15, 2002 Share November 15, 2002 I mean buy his second hand Koni...... ↡ Advertisement Link to post Share on other sites More sharing options...
Where to modify seat rail/bracket?
Where to mod fuel needle?
Where to get those plastics that allow your to stick the road tax/decal on screen
Wheel Spacer, where to buy?
Where you cut your hair?
Going to Batam. Where to park overnight ?
NBA - Where Amazing Happens
