Optra Speedometer / Odometer
Cbtan
Hi Bro...
I collected my optra last sunday. This morning, while driving to work, found that the speedometer (the meter display with km/h) did not response well. Noticed also it can't go down to "0" when the car completely stop. It will remained at certain speed even though I slow down the car, the pointer will move down only after awhile. [:(] Anyone encounter such problem?
The SE told me not a serious problem. Have made appointment to service the car for 1000km service 2 weeks later. Will try to rectify this problem then.
Didn't encounter this before.. except the rpm..
By the way, my friend who also collected his optra on Sun had the fuel guage problem... Dunno what the SA doing man.. getting worst..
Hi Bro
Overall, very satisfy with the car and my SE. However, didn't expect this problem can happen to a new car. [:/]
Also, me very "suay", accidently dented the rear bumper (not obvious though). Do you think this can be fixed during the 1st service as well at SA service centre? Or, need to go somewhere else to get it fix. Read other posting on this matter, seemed that autopoint at amk is good at this.
U got your RPM problem fixed yet?
me oso got RPM problem, was solved by re-setting ECU last month by SA.
But now its back, seems to me there was no permanent solution.
Oh, what RPM problem ?
I had mine, when I start engine, the RPM jump to 2k.. go down very slowly.. Especially so when engine is warm. Morning not that bad, but still noticable.
Went to reset 2 times already.. now back..
Hi Bros,
I am very new in this forum and have been reading topics that pertaining to Optra.
I have my Optra about 2 mths back and had the symptom actually like what you have descriped, that was when "start engine, the RPM jump to 2k.. go down very slowly.. Especially so when engine is warm"
Went back for reset once. Notice that it is normal for the RPM to jump to 2K when start but should come down slowly, also realises that the problem occured only when I had switch fro Ron 95 to Ron 98. Similar to you after you had changed from Ron 92 to Ron 95. Not sure was this has any relation to the high RPM when start.
Edited by Chevyoptrag
I know the Dec 26th Meetup (Sunday) will be at Kallang, but does any interested to just show-up at SA on morning of Dec 24th (no appt) and start listing each of this issues? gossip.gif
Yeap, boss declare off-day on Dec 24th
1.
2.
3.
4.
5.
6.
7.
8. DonDon
9.
10.
Hello Chevryoptrag,
When I first got the car, and after every "reset" of the ECU, when I start engine, regardless of cold or warm, it should be "Engine goes to 1.5krpm or 2krpm, and drops IMMEDIATELY to 1krpm or 900rpm". Immediately, to me, is less than 2 seconds.
Actually, I do not think the petrol change from 92 to 95 has anything to do with it, cos the change happened for at least 5 tankful before the first time it appears. After than, no change in petrol grade.
Oh, another test to see if your problem is the same as mine :
(1) After you drive to office, Put auto-gear to [P], Pull handbrake, off Engine. Wait for about 10 seconds.
(2) Start engine. Engine RPM will now be 2krpm, and maintain for 1 or 2 seconds, then drop to 1.5krpm, for another 2 seconds, than drop to 1krpm.
(3) Press Accelerator until Tachometer move to 2-2.2krpm, let go accelerator.
My RPM will MAINTAIN at 2krpm for another 3 to 5 seconds before dropping slowly ! sweatdrop.gif
Normal engine, it should start dropping down very fast to idling 1krpm within 1 or 2 seconds.
Sounds like got ghost step on my accelerator , even after I let go. shocked.gif
sent car in wrt the RPM prob this morning, ask advisor why 2nd time liao, got standard answer: they will check and give me a stone face [:|] (a lady).
wah lau how to complain... [furious]
saw another Optra juz delivered 1 mth, and have fuel indicator prob..really screw up [dead]
Think all this repeating minor quality issues really spoil the experience of owning an Optra, hope GM can see our feedback.
Cool down man! [nod]
I got really frustrated too with the problem on my speedometer. Just have to go back and fix it. I have booked appointment to fix it and hopefully, it won't come back again. This morning, I noticed also my rpm meter a bit "siaw siaw". move only when accelerate. If I stop pedal, eventhough the car is moving at a speed of 70km/h, the pointer will move back to 1rpm(car stopping condition). [:|]
Hi all. I would suggest that those vehicle with problems that SA did not rectified after a few times servicing to organise a meetup at SA showroom every month 1 of the Sat afternoon. Park our vehicle in-front the showroom and put up notice "Problems car, help us rectify! StarAuto!". Call reporter in as well. [idea] Scare away their potential customer. [bounce2] See whether they will entertain our complain! [thumbsup] ON boh?
1. Botak
2.
3.
4.
5.
6.
7.
8.
9.
10
Edited by Botak
[reply]
I got really frustrated too with the problem on my speedometer. Just have to go back and fix it. I have booked appointment to fix it and hopefully, it won't come back again. This morning, I noticed also my rpm meter a bit "siaw siaw". move only when accelerate. If I stop pedal, eventhough the car is moving at a speed of 70km/h, the pointer will move back to 1rpm(car stopping condition). unimpressed.gif
Correct, if you release the pedal, it will drop to 1krpm.. and cruise at so-called "free gear". That is how auto does it.. Engine-brake effect not like manual..
