Tool to change Spark Plug
Gylgyl
Turbocharged
I just realised this thread is about the tools needed
from right to left
torque wrench
3/8" sliding T bat + 3/8" extension + 3/8" spark plug socket = spark plug removal tool
old shoe lace to wrap around the spark plug boot to pull them out (they are super tight)
1/4" ratchet + 1/4" extension + 1/4" E8 socket (to remove the ignition coil)
feeler gauge
also, lots of lights
this is E-Torx, you need a set when you work on German car
a 14mm spark plug socket, it is different from a normal 14mm deep socket
spark plug socket has a magnet (some has rubber boot) inside to hold the spark plug and it has thin wall
a normal 14mm deep socket may stuck in a spark plug hole if the hole is small
6th Gear
from right to left
torque wrench
feeler gauge
IMHO.
I need a car to practice on. 🤣
  • Haha! 2
Turbocharged
On 7/15/2024 at 1:28 PM, Kklee said:
IMHO.
I practice it on my wife's car 🤣
  • Haha! 1
Supersonic
IMHO.
Most car is very easy to change.
The plug is exposed on top. Just remove the top panel . 1 screw for each plug coil. Then can reach the plug liao.
But some car is extremely hard. Like fit or jazz. U need remove the wiper etc etc . Or some car need remove manifold.
If your car is such cases . Better dun try 😅
  • Shocked 1
Turbocharged
yes, it is low hanging fruits in my wife's car case 😁
merc moved the spark plug location of their new engines from top centre to side, making it very easy and accessible to change
top centre hole is for direct injector, the sideway hole between the exhaust valve is the spark plug hole
you can see the spark plugs are located at the side of the cylinder head, like the old SOHC engine even though this is a DOHC engine
