Turbobrick Neutral Newbie November 12, 2002 Share November 12, 2002 Like Fabiaman mentioned, AMSOIL spec-ed up to 25kmiles but in severe driving conditions like start-stop traffic, AMSOIL can last up to three times the manufacturer's interval. My Volvo stats change oil 15k km for normal conditions and 5k for severe conditions, so AMSOIL can push up to 15k km for severe conditions in this case. I do stress that the oil filter should STILL be changed every 5000km. ↡ Advertisement Link to post Share on other sites More sharing options...
Fabiaman 1st Gear November 16, 2002 Share November 16, 2002 For those unfamiliar with the discussion here abt AMSOIL's draining intervals, I have reproduced a short write up on the Engine Oil which MCF is selling. PROVIDES EXTENDED DRAIN INTERVALS AMSOIL High Performance Synthetic 10W-40 Motor Oil features a superior synthetic composition and advanced performance additives, performing much longer than competing conventional and synthetic oils. No other major oil manufacturer matches AMSOIL's 25,000-mile or one-year drain interval recommendations. Does sound a bit far fetch to drain at 25k miles but this is direct words from the manufacturer. Also note this is base on US context, not that their cars are different from ours, but more of the driving conditions which is diff. Link to post Share on other sites More sharing options...
Ezlife Neutral Newbie November 16, 2002 Share November 16, 2002 Woah...! hiong arh. that equilvalent to 40225km !!! hiazzz, my workshop doesnt recommend me bringing other brands of oil for servicing. they wanted me to use theirs instead, Duckams. Hear that name i siazz 1/2 liao. Link to post Share on other sites More sharing options...
Guyver 1st Gear November 16, 2002 Share November 16, 2002 No lah... that's for US kind of environment and temperature as well..... somemore.... they say... "... or 1year drain interval...."... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie November 17, 2002 Share November 17, 2002 Actually Honda claims that all their new oil filter last 20,000km !!! Can someone double confirm ? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 17, 2002 Share November 17, 2002 Normal driving conditions I presume? that's good for a year of filtration....which I personally would not try....6months is the most I'll push. Link to post Share on other sites More sharing options...
Fabiaman 1st Gear November 18, 2002 Share November 18, 2002 Andrew, guess it depends how much is the cost of that oil filter. If its cheap like $10 each, I'd rather change it often like every 10k. If its exp like $30, I'd be more inclined to believe them.... also bo pian because being expensive, you can't change the filter as often as you like (unless you have fat wallets) Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie November 18, 2002 Share November 18, 2002 It's those $7/pcs kind ... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear November 19, 2002 Share November 19, 2002 Fabia, Are you the one keeping the mintex pad, if yes, please reply to this thread. http://www.mycarforum.com/forum/gforum.cgi...ollapsed;#78384 Link to post Share on other sites More sharing options...
Alfpoon Clutched November 19, 2002 Share November 19, 2002 Just curious, how can we change the oil filter without changing oil? When you remove the filter, doesn't the oils spill out immediately? Am I wrong? Link to post Share on other sites More sharing options...
Admin Clutched November 19, 2002 Share November 19, 2002 Thanks Gadgeter, we have gotten in touch with the interested forumer. Cheers! Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie November 19, 2002 Share November 19, 2002 "doesn't the oils spill out immediately?" Hi! there, Alfpoon, Some oil will drip out, but not all. Replace with new filter and top-up. Rgds Paul Yong Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 19, 2002 Share November 19, 2002 The oil that is in the filter will spill (depending on the angle of the filter as well), but less than 0.5 litres should be lost if done right Link to post Share on other sites More sharing options...
Alfpoon Clutched November 20, 2002 Share November 20, 2002 Yo Paul, looks like i need to stock up more oil filters soon...running out. Going to Tanly? Link to post Share on other sites More sharing options...
Alfpoon Clutched November 20, 2002 Share November 20, 2002 Thanks TB...I guess my next question would be how to do it right? Hmm..next servicing I'll watch the guy change my filter learn a thing or two. Link to post Share on other sites More sharing options...
Luckcent 4th Gear November 20, 2002 Share November 20, 2002 How often do you change the filter. Link to post Share on other sites More sharing options...
Alfpoon Clutched November 20, 2002 Share November 20, 2002 at every oil change..say 8kkm to 10kkm. In the event if AMSOIL can last longer, the oil filter have to be changed earlier as advised by some right? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 20, 2002 Share November 20, 2002 Changing filter is pretty easy, depends on where your filter is located it may be reachable from the top. A filter wrench will definitely help if U're considering DIY. AMSOIL will last up to three times longer than manufacturer's recommendation, so if Alfa recommends 5k for severe driving (start-stop, constant high speed, etc) than it'll be 15k on AMSOIL ↡ Advertisement Link to post Share on other sites More sharing options...
Any amsoil alternatives?
Where to get cheap AMSOIL EO?
Explosion rocks central Bangkok, casualties seen
Assistance needed!
Assistance needed!
Amsoil VS Redline
Amsoil VS Redline
CSC3 Rocks!
CSC3 Rocks!
Amsoil oil distributor
