Madarmour Neutral Newbie November 9, 2002 Share November 9, 2002 (edited) The main work of heat removing should be the radiator itself. The design of the tube, large bore, rubber compound, no cooling fins, poor air circulation, makes it more like a conduit to carry water rather than actual cooling. I do agree with you that any benefit from wrapping the hoses will be minimal. Edited November 9, 2002 by Mikeckchong ↡ Advertisement Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 9, 2002 Share November 9, 2002 I don't wrap the hoses myself as I don't see much benefit in doing that. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie November 9, 2002 Author Share November 9, 2002 1.7L is the normal layout, header in front, intake behind. 2.0L is different, header behind, intake infront. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 9, 2002 Share November 9, 2002 Ahhhhh so...............sorry for the mistake then......... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie November 9, 2002 Author Share November 9, 2002 Hehee ... no prob ..... Was looking at a Corolla yesterday, wow, then engine bay so spacious ! For the Stream, the bonnet is only 88cm long !!! They basically squeeze everything into that small space ! Thus a lot of things unreachable. Imagine, changing headlight also must remove a few reserviors (I mean power steering reserviors, washer reserviors, not the BIG water catchment reserviors :-P) !!! So, trying to keep heat away from each other. Also, can you believe it ! , the air con low pressure pipe runs nearly directly across the engine block!!!! **See pics ** Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie November 9, 2002 Author Share November 9, 2002 (edited) Attached is another pic, showing why I am considering wrapping the radiator hose. - Very near to air hoses (inlet, box), thus am worried about the emitted heat However, the engine block also emit heat, so I dunno how much it will help leh Edited November 9, 2002 by Andrewkb Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 10, 2002 Share November 10, 2002 Then it's probably more worth your while to insulate the airbox and air inlet hoses rather than the radiator hose bro Mike, wadda U think? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 10, 2002 Share November 10, 2002 Looks like it's gonna be quite a difficult job wrapping the hose as it appears to be quite tight there. How about doing a heat shield? BTW, like what Turbobrick suggested, I believe you'll get more improvement by wrapping the air intake hose instead. In this case, you'll be able to insulate the air hose from the water tube AND the engine heat at the same time. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 10, 2002 Share November 10, 2002 I think you're right! ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator Cap
Radiator Cap
Radiator slight crack
Using hose in mscp
Using hose in mscp
Coolant overflowing from expansion tank
How useful is higher pressure radiator cap?
Radiator tank leaks
Radiator tank leaks
Plastic weld
Plastic weld
How to protect your radiator from debris and damages
