Eyke Supercharged December 26, 2019 Share December 26, 2019 1 hour ago, GTO-1 said: At least to make it productive, if comfort, quietness and cheap are at the top of your list then the f1a5 and ps4's are not the tyres you should be talking about. there's no 215/50R17 for F1A5, Goodyear only have EfficientGrip for this size... ↡ Advertisement Link to post Share on other sites More sharing options...
Kia0042 2nd Gear December 26, 2019 Share December 26, 2019 True enough, I am not a car person. Sorry for asking the stupid 17" rim fir a 18" tyre question. Sound like I need to go to a reputable tyre shop to get them all change. Perhaps, the term loss of traction has over described my current issue, when rear wheel sway a little bit and loss of a bit of grip while driving over a road patches at 70km/hr at a bend, what is the correct term to say? By the way, 17" tyre, quiet + comfort + grip, estimated $200-$250 per piece is reasonable price? Quoted by my regular car service center. Brand ? forgotten, not some brand name that I can remember easily. Link to post Share on other sites More sharing options...
Beregond Supersonic December 26, 2019 Share December 26, 2019 38 minutes ago, Kia0042 said: True enough, I am not a car person. Sorry for asking the stupid 17" rim fir a 18" tyre question. Sound like I need to go to a reputable tyre shop to get them all change. Perhaps, the term loss of traction has over described my current issue, when rear wheel sway a little bit and loss of a bit of grip while driving over a road patches at 70km/hr at a bend, what is the correct term to say? By the way, 17" tyre, quiet + comfort + grip, estimated $200-$250 per piece is reasonable price? Quoted by my regular car service center. Brand ? forgotten, not some brand name that I can remember easily. very very few performance tyres come in 50 profile. potenza re003 is 1 of them, i advice u to try this 1 if u not really very particular about noise. and u need to know lost traction on dry road, and on raining days is different issue. Link to post Share on other sites More sharing options...
Eyke Supercharged December 26, 2019 Share December 26, 2019 (edited) 1 hour ago, Kia0042 said: By the way, 17" tyre, quiet + comfort + grip, estimated $200-$250 per piece is reasonable price? i think not, for ur ref: https://www.amtyre.com/shop/?swoof=1&tiresize=17-50-215 Edited December 26, 2019 by Eyke Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 26, 2019 Share December 26, 2019 (edited) 7 hours ago, Kia0042 said: Asking 3 questions from you guys expert on rims and tyres. Q1- My 18mths old ride original rims and tires are 215/50/r17 91v. Done 24k+ mileage. I have a problem - loss of traction when running over road patches, especially at speed above 70km/hr along a bend roads. I can feel the rear wheels slipped when I ran over the patches. I have done alignment, rotation whenever go servicing, it this tires problem or other issue? Q2- Can I change 18" tires into my existing 17" rim? Q3- Looking for quiet, comfort and grip tires. Goodyear Eagle Asymmetric and Michelin PS4 which is quieter and cheaper? Your wheels lost traction when driving over water puddle may not necessarily be worn tyre thread , it could simply be you are driving too fast over a bigger, deeper water puddle. It is the effect of aquaplaning. If your car is rear wheel drive and you like to slap hard most of the time, 24k km can cause significant wear to your thread, did you check against the thread wear indicator on the tyre? Answer to q 2 is a no. Meantime, it is raining season, drive slowly to be safe. Edited December 26, 2019 by Ct3833 1 Link to post Share on other sites More sharing options...
GTO-1 5th Gear December 26, 2019 Share December 26, 2019 (edited) 6 hours ago, Kia0042 said: True enough, I am not a car person. Sorry for asking the stupid 17" rim fir a 18" tyre question. Sound like I need to go to a reputable tyre shop to get them all change. Perhaps, the term loss of traction has over described my current issue, when rear wheel sway a little bit and loss of a bit of grip while driving over a road patches at 70km/hr at a bend, what is the correct term to say? By the way, 17" tyre, quiet + comfort + grip, estimated $200-$250 per piece is reasonable price? Quoted by my regular car service center. Brand ? forgotten, not some brand name that I can remember easily. Nothing to be sorry about. Just be safe on the roads, for yourself and people around you. Still doesn't sound safe, what you describe. Sounds like you're not far off oversteer (the rear losing traction), and I would hazard a guess that 90% of drivers wouldn't know how to control an oversteer and would likely loose control. Heck, even F1 drivers have trouble with unexpected oversteer. Perhaps you're driving around a bend too fast? 70kph around a bend might be pretty fast depending how sharp that bend is? 2 hours ago, Ct3833 said: Your wheels lost traction when driving over water puddle may not necessarily be worn tyre thread , it could simply be you are driving too fast over a bigger, deeper water puddle. It is the effect of aquaplaning. If your car is rear wheel drive and you like to slap hard most of the time, 24k km can cause significant wear to your thread, did you check against the thread wear indicator on the tyre? Answer to q 2 is a no. Meantime, it is raining season, drive slowly to be safe. If he's aquaplaning, then the entire traction would be lost and he would have no control whatsoever. Aquaplaning is all or nothing. There isn't a semi-aquaplane. That's because the tyre is traveling over the surface of the water at speed and has no contact to the actual ground, which provides the friction required to turn the car or brake the car. I suppose you could argue that his tread depth might be too low, to be able to effective clear the water. Who knows. Its a pretty serious problem though. Edited December 26, 2019 by GTO-1 Link to post Share on other sites More sharing options...
Kia0042 2nd Gear December 27, 2019 Share December 27, 2019 (edited) 13 hours ago, GTO-1 said: This is the bend I referred. I travel BKE - KJE via Gali Batu Flyover almost everyday and I have to avoid running over this particular patch (red circle). Never drove above 70km/hr along this stretch of road. Anyway, I am going to change my tires this weekend. It has been a while I have not drive above 120km/hr. Safety number 1. btw... can change to 225/50R17 91V tires (current 215 50r17) look better with wider tyre. Edited December 27, 2019 by Kia0042 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 27, 2019 Share December 27, 2019 23 hours ago, Kia0042 said: Asking 3 questions from you guys expert on rims and tyres. Q1- My 18mths old ride original rims and tires are 215/50/r17 91v. Done 24k+ mileage. I have a problem - loss of traction when running over road patches, especially at speed above 70km/hr along a bend roads. I can feel the rear wheels slipped when I ran over the patches. I have done alignment, rotation whenever go servicing, it this tires problem or other issue? Q2- Can I change 18" tires into my existing 17" rim? Q3- Looking for quiet, comfort and grip tires. Goodyear Eagle Asymmetric and Michelin PS4 which is quieter and cheaper? Q1; I assume you experience it after driving 24+k. Check your tread depth. If it is 3mm or below, change your tyre. Q3: There is a compromise between quiet and grip especially wet grip. Link to post Share on other sites More sharing options...
Columbian78 6th Gear December 27, 2019 Share December 27, 2019 12 minutes ago, Kia0042 said: I am using 225/50/17 f1a3 on my car without issue. The stock size was 205/50/17. And my car is lowered slightly on coilover. What i am saying is there will not be major issues. Long term effects or minor issues i cannot say for your car. Link to post Share on other sites More sharing options...
shutterbox 3rd Gear January 8, 2020 Share January 8, 2020 On 12/26/2019 at 2:09 PM, Kia0042 said: True enough, I am not a car person. Sorry for asking the stupid 17" rim fir a 18" tyre question. Sound like I need to go to a reputable tyre shop to get them all change. Perhaps, the term loss of traction has over described my current issue, when rear wheel sway a little bit and loss of a bit of grip while driving over a road patches at 70km/hr at a bend, what is the correct term to say? By the way, 17" tyre, quiet + comfort + grip, estimated $200-$250 per piece is reasonable price? Quoted by my regular car service center. Brand ? forgotten, not some brand name that I can remember easily. Can try Dunlop veuro ve303, they have 215/50r17 Link to post Share on other sites More sharing options...
westwest1 1st Gear January 14, 2020 Share January 14, 2020 sound more like worn suspension parts then is tires.... Link to post Share on other sites More sharing options...
Sdf4786k Twincharged March 5, 2020 Share March 5, 2020 Never seen a tire with a sponge inside the tires b4. I know , I am a noob right. ☺️ ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
New Study Explores Connection Between The Size Of Your Manhood And Sports Cars
Tire size not available in Singapore, how?
Do I need to change tire ?
Tire patching types and prices
Spare tire. do u remove or leave in boot?
Continental's New Sustainable Tire Concept Revealed At Munich
