Hensony Clutched November 30, 2004 Share November 30, 2004 Is it true that a car with a smaller engine capacity is more fuel efficient? Take the example of Toyota Passo. It comes in 1.0L and 1.3L versions. Given the same configurations except for the engine size, is the 1.0L more fuel efficient than the 1.3L? Please enlighten. ↡ Advertisement Link to post Share on other sites More sharing options...
Acemundo Supercharged November 30, 2004 Share November 30, 2004 generally yes...but exceptions does occur whereby for certain car the weight is beyond the optimal range. that's to say if u let the 1.0cc carry a weight heavier than what capacity is meant for then the fuel consumption can be higher. ie over-strained it might consume more petrol? Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear November 30, 2004 Share November 30, 2004 fuel efficiency depends on the type of driving u do... a 1 litre car on a highway @ 120kph would prob be using more fuel per km than a 4.3litre lexus at that same speed. but the opposite occurs if ur running ard orchard road doing errands... everything is variable. buy a car that suits your needs... Link to post Share on other sites More sharing options...
Sotong_kia Neutral Newbie November 30, 2004 Share November 30, 2004 Fuel efficiency and fuel consumption are 2 different things. Imagine I drink water by pouring water from water fountain.. a lot of the water is wasted and flow from the side of my mouth into the drain. I am inefficient. But the amount of water I drink + wasted in one day is still less than the water that an elephant drinks in one day. Efficiency is usually measured by km/l. And can only compare different cars/engines under identical/similar conditions. Link to post Share on other sites More sharing options...
Looneytune Neutral Newbie November 30, 2004 Share November 30, 2004 that's a good way to illustrate! Link to post Share on other sites More sharing options...
Potheader Clutched November 30, 2004 Share November 30, 2004 You are not that blur after all! Link to post Share on other sites More sharing options...
Pioneer 4th Gear November 30, 2004 Share November 30, 2004 Quote Is it true that a car with a smaller engine capacity is more fuel efficient? Take the example of Toyota Passo. It comes in 1.0L and 1.3L versions. Given the same configurations except for the engine size, is the 1.0L more fuel efficient than the 1.3L? Please enlighten. I think is more correct to say smaller engine capacity GENERALLY consume less petrol as compared to bigger capacity Link to post Share on other sites More sharing options...
Accenture Neutral Newbie November 30, 2004 Share November 30, 2004 yes generally true but a small engine in a heavy car is going to cause you to burn more fuel to get the car moving. There is always an optimal trade off. Link to post Share on other sites More sharing options...
Genie47 1st Gear December 1, 2004 Share December 1, 2004 Engine design plays a part and not just the displacement. GM cars with the 1.2L Ecotec derived unit have very poor FC compared to the 1.4L versions. Link to post Share on other sites More sharing options...
Guyver 1st Gear December 1, 2004 Share December 1, 2004 Quote Is it true that a car with a smaller engine capacity is more fuel efficient? Take the example of Toyota Passo. It comes in 1.0L and 1.3L versions. Given the same configurations except for the engine size, is the 1.0L more fuel efficient than the 1.3L? Please enlighten. Generally yes... but different usage patterns will yield different consumption.... Link to post Share on other sites More sharing options...
Porker Turbocharged December 1, 2004 Share December 1, 2004 I think the ratio between FC (km per litre) and the weight of the car is a good guage of the fuel efficiency assuming all other conditions are held constant. Link to post Share on other sites More sharing options...
Spacio1 Neutral Newbie December 2, 2004 Share December 2, 2004 Quote Is it true that a car with a smaller engine capacity is more fuel efficient? Take the example of Toyota Passo. It comes in 1.0L and 1.3L versions. Given the same configurations except for the engine size, is the 1.0L more fuel efficient than the 1.3L? Please enlighten. I used to drive a 1.3l corolla but the consumption (km/l) is worst than 1.6l corolla.. because weight:power ratio is high.. The engine has to work harder to get the car moving.. ↡ Advertisement Link to post Share on other sites More sharing options...
More MRT Lines Announced
