Lrrp Neutral Newbie November 28, 2004 Share November 28, 2004 Just got a second hand fog light from someone who is scrapping his ride. My car has no pre-fabricated slot for the original toggle switch for the fog lights (original setting is to toggle the fog lights on/off when at least the parking lights are turned on). Hence I had the fog lights cables connected to the parking lights instead, ie. the fog lights will turn on when I switch on the parking lamps, and of course when the main head lamps are on. Was not able to link up with the indicator on the dashboard as I was told the wiring would be much more complicated. Anyone got a similar experience with his / her fog lamps? Is this setting LTA compliant (I had imagined so)? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear November 29, 2004 Share November 29, 2004 what is your ride? Link to post Share on other sites More sharing options...
Lrrp Neutral Newbie November 29, 2004 Author Share November 29, 2004 Mitsubishi Lancer ('02 model, or Cedia) Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear November 29, 2004 Share November 29, 2004 maybe you can install another swtich instead... ↡ Advertisement Link to post Share on other sites More sharing options...
Cyclops Rear Light - Who came up with it first?
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
P2096 Check engine light
