Dptm Neutral Newbie November 1, 2002 Share November 1, 2002 Hi Know that it's late asking this, since i've already changed the front 2 springs to aftermarket (and lower) type. But are there any ill effects or things i should look out for? BTW, the rear is still stock. ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 1, 2002 Share November 1, 2002 Well I'd advise against it. Firstly you'll be wearing out your front suspension bushings and components if the car sits lower in front (kinda tilted). Also tire wear may suffer and weight distribution of your car definitely will be thrown to the front (not much but remember FWD already front heavy). Link to post Share on other sites More sharing options...
Dptm Neutral Newbie November 1, 2002 Author Share November 1, 2002 didn't know it could be this bad i was too impulsive. should i change back to the stock springs... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 1, 2002 Share November 1, 2002 Are you on stock shocks? Are rear lowering springs available and how long U intend to keep the car? It'll probably be ok for around 2yrs before problems start to show. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie November 1, 2002 Share November 1, 2002 Then again, if the aftermarket springs are speical made for the stock supension, it may be lesser side-effect. Dun forget need the alignment after install. So suggested that should change the whole sets better. Link to post Share on other sites More sharing options...
Dptm Neutral Newbie November 1, 2002 Author Share November 1, 2002 all 4s are on monroe shocks. i wanted comfort with lower look and was recommended to change only the front. another 3 yrs probably. Link to post Share on other sites More sharing options...
Yongwd 1st Gear November 2, 2002 Share November 2, 2002 for lowered look + comfort + durability + fun fun fun = coil over + camber correction kits. simple? Link to post Share on other sites More sharing options...
Dptm Neutral Newbie November 2, 2002 Author Share November 2, 2002 ok...i was too impulsive think i will change it back to stock then. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 2, 2002 Share November 2, 2002 Not to mention more diving when you brake. Instead of changing the front back to stock, why don't you get an extra pair for the back too? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 2, 2002 Share November 2, 2002 Wah, who's the mechanic? I'll make sure I stay far, far away from him! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 2, 2002 Share November 2, 2002 Coilover = comfort???? Sure or not???? Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 2, 2002 Share November 2, 2002 coil over = lowered look + harder ride, I don't think it will be comfortable Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie November 3, 2002 Share November 3, 2002 Monroe Sensatrac? Those don't last long, I suggest U revert to stock. Lowered springs are best coupled with monotube gas shocks that are rated higher than stock as the lowered springs add additional load on the shocks. Link to post Share on other sites More sharing options...
Presea 3rd Gear November 3, 2002 Share November 3, 2002 I've been using Monroe Sensatrac for almost a year now. Had them installed after I realised that my new (then) low profile tyres were getting uncomfortable with my stock suspension setup. After I switched to them, I felt the increased comfort almost immediately, with less shuddering when I go over uneven surfaces...and after going over humps, the dampers work so much more effectively, with little to no bounce...and still not uncomfortable. As an avid enthusiast, I do push my car very hard....and the Sensatrac shocks have taken a lot of abuse....everyday. They haven't let me down yet...but I'm looking to move on to a lowered springs and shocks setup. Sensatrac no matter how good (to me), are still comfort level shocks, that can't remove the bodyroll I get when I enter a corner slightly too fast, and ultimately I would prefer something with a lowe ride height. I have been advised from lowering my springs with Sensatrac still installed....they're not meant to be used with such springs.... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 3, 2002 Share November 3, 2002 Coilovers, coilovers! Any thought of changing to that? Link to post Share on other sites More sharing options...
Yongwd 1st Gear November 3, 2002 Share November 3, 2002 yeah yeah!! Coilover is the word Link to post Share on other sites More sharing options...
Yongwd 1st Gear November 3, 2002 Share November 3, 2002 strange, there are comfort range coilovers slightly stiffer then stock, (eg, Tein CS type) unless you talking about those for track use ...? i think comfort will not be that terribly compromised Link to post Share on other sites More sharing options...
Presea 3rd Gear November 3, 2002 Share November 3, 2002 aren't coilovers like .....EXPENSIVE will decide when my Sensatrac fail after too much abuse have been dashed out....maybe a few PG trips will help accelerate that... But I thought of progressing from stock to lowered...to adjustables...than to coilovers last. From what I've gathered, coilovers are best for track days.....is that true? ↡ Advertisement Link to post Share on other sites More sharing options...
Washing machine front loading
All about springs and shocks(dampers)
Front lower arm and suspension questions
How to migrate aust , nz with only engineering deg ?
Herbal tonic wine (any side effects?)
Noise from front engine area (suspension,maybe) when hit bump with left turn
Different front and rear tires
Front/rear strut bar & lower tie
