Misterray Neutral Newbie November 17, 2004 Share November 17, 2004 hey guys wats the function of an amplifier in your system man?? ↡ Advertisement Link to post Share on other sites More sharing options...
Nemesis Neutral Newbie November 17, 2004 Share November 17, 2004 Amplifiers: A power amplifier takes an input signal, usually a preamp level signal, which has both low current and low voltage characteristics, and produces an output which will have higher current and voltage levels. The power supply available to the audio output IC in a head unit is limited to the battery voltage of the vehicle. This means that the head unit can produce an audio signal with a limited (by the battery voltage) voltage swing, and therefore a limited power output to the speaker. Most amplifiers have a special circuit (switching power supply) to boost the available battery/charging system voltage to a higher voltage. The higher voltage developed in the amplifier's internal switching power supply will allow the audio output voltage swing to be greater. This allows the amplifier to produce more power into the speakers connected to the amplifier's output terminals. Link to post Share on other sites More sharing options...
Misterray Neutral Newbie November 17, 2004 Author Share November 17, 2004 so in a way it improves the sound quality lah. so is it possible to connect an amplifier to the stock speakers? Link to post Share on other sites More sharing options...
Wankie Clutched November 18, 2004 Share November 18, 2004 Its possible but IMHO, its probably better to change the stock spkrs 1st, then see if you'll like to add an amp later. btw, if you're into GnR go the whole hog & get the amps & woofer Link to post Share on other sites More sharing options...
Nemesis Neutral Newbie November 18, 2004 Share November 18, 2004 Bro, U hardcore Link to post Share on other sites More sharing options...
Biohazard 1st Gear November 18, 2004 Share November 18, 2004 It is possible to connect but i dun think u'll be fully utilising the amp leh Link to post Share on other sites More sharing options...
Wankie Clutched November 19, 2004 Share November 19, 2004 lidat hardcore meh mellow liao lah, age is catching up but i think that config is more than enough for normal drivers, unless he the siao ICE type Link to post Share on other sites More sharing options...
Nemesis Neutral Newbie November 19, 2004 Share November 19, 2004 U must have gotta antidote for the poison, manage to put the brake juz on time Cheers Link to post Share on other sites More sharing options...
M2vrm Neutral Newbie November 19, 2004 Share November 19, 2004 Hi, can advice which should I choose, a 100WX2ch for the front comp spks or a 35WX4ch for front and rear spks. Which is a better choice? cheers Link to post Share on other sites More sharing options...
Wankie Clutched November 22, 2004 Share November 22, 2004 Send me a bigger pic of your avatar then i tell u ha ha, joking only bro. My 2 cents but take it with a pinch of salt 'cos i not ICE expert. For me, nothing beats having the power to drive the speakers provided your speakers can take it. I'm currently using a 230Wx2ch amp for the front comp spkrs, i don't hv rear spkrs. 35W/ch you might as well stick to your HU But if you're looking for potential expandibility, get a 4 ch amp. Link to post Share on other sites More sharing options...
Wankie Clutched November 22, 2004 Share November 22, 2004 ya man, always hv to know when to stop Link to post Share on other sites More sharing options...
M2vrm Neutral Newbie November 22, 2004 Share November 22, 2004 haha, how about bridged the 4 ch to use for the front only. when bridged the 4 ch will the power better than the 100Wx2ch. ? undecide which will give better ? Cheers, Link to post Share on other sites More sharing options...
Wankie Clutched November 22, 2004 Share November 22, 2004 err, dunno ah but i think theoretically shld give better sound as u are using 1 ch each to drive the tweeter & the cone, but depends on how much power your amp outputs in bridged mode, but seriously, i'm lost ↡ Advertisement Link to post Share on other sites More sharing options...
Butler Tube Amps - Anywhere to repair locally?
Need suggestions - Amps & DSP
Selling my 2 amps
Selling my 2 amps
I.C.E without additional amps
Amps Technical Data What it means
Does Install Amps affect Car performance?
Carver amps
Carver amps
Installation of front n rear speakers, sub and 2 amps to integrated HU
