Correct gap for Splitfire spark plug - Altis 1.6
Sil96verman
Spark cables in the good old days are make of thin copper wire twist together. These type of cables creat alot of noise and cause radio interference. The high Kilovolt passing through the cables has to be supressed so many military vehicles has steel braided cable.
Today's cables are basically consist of carbon cord and which are less resistance to the flow of electricity. High performance cord had outer layer make of silicon to within higher engine temp.
so as long as the gap size is right.....any plugs oso can use???
btw, mine is 1.5L Aveo. gap size is 0.7-0.8. can last 10-20k.... what do u suggest,bro?
like that cham ley! Denso IK16 is gap size 1.1mm, unless you want to regap it sweatdrop.gifsweatdrop.gifsweatdrop.gif
Yes you are correct, coil-on-plug will cut out the Kv loss due to wire resistsance.
