Sil96verman Neutral Newbie November 16, 2004 Share November 16, 2004 All sifu out there. Do anyone know what is the correct Splitfire Triple Platinum spark plug gap width for Altis 1.6. Thanking in advance..... FYI I didnt buy from the distributor (Autodesign), asked a friend to buy from USA. Cheaper but dont know the original gap width is correct or not. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 23, 2004 Share November 23, 2004 Just try with 20% more opening and drive around.If the power is good maybe increase by another 20% if not just reduce by 10%. Link to post Share on other sites More sharing options...
Hattee Neutral Newbie December 2, 2004 Share December 2, 2004 Standard plug has to be gapped correctly to ionise effectively at certain voltage. But performance plug ionise at lower voltage, hence, its gap should not cause any problem with most NA cars. Even if you want to re-gap performance plugs, probably will damage its fine eletrode or upset the balanced gap among multi-electrode to ground. You don't usually re-gap them. Link to post Share on other sites More sharing options...
Genie47 1st Gear December 3, 2004 Share December 3, 2004 Like Hattee said. Cannot anyhow re-gap the plugs as most plugs are already gapped specifically for your engine if you follow the manual. Gapping plugs actually belongs to the realm of the hardcore tuner in race preparations. Tell you what. Most spark plug mfr websites have cross-referencing charts or searches. Find out the plug your car uses. Usually I believe it is either an NGK number or Denso number. Cross reference it at the Splitfire website. Link to post Share on other sites More sharing options...
Esky Neutral Newbie December 23, 2004 Share December 23, 2004 I think now most cars use 1.1mm gap. I'm now running 1.3mm on a set of Denso Iridium without any problem, but then again, I seldom do hi-rev or full throttle. If you do these 2 things often, u shd set it at the recommended gap or slightly below, for more consistent firing at hi revs or dense air/fuel mixture situations. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 23, 2004 Share December 23, 2004 Gap setting depends on the coil or ignitor's kilovolt output. The std output is about 25kv and by the time it reaches the plug( due to spark plug cable resistance) the high voltage available maybe about 18kv. If you replace the OEM stock coil with aftermaket high energy coil ,you also need to replace the stock spark plug cables with performance types such as silicon cables that can within stand high KV passing through without overheating. In turns you have to set the plug gap much wider than the std setting so as to allow the high KV to perform a better sparking. Link to post Share on other sites More sharing options...
Esky Neutral Newbie December 23, 2004 Share December 23, 2004 Yeah, that's what my friend who was using an Accel coil told me, that he could use a very big gap for better performance. Any ideas how much the Accel coil is selling for? Link to post Share on other sites More sharing options...
King 1st Gear December 24, 2004 Share December 24, 2004 Gap setting depends on the coil or ignitor's kilovolt output. The std output is about 25kv and by the time it reaches the plug( due to spark plug cable resistance) the high voltage available maybe about 18kv. If you replace the OEM stock coil with aftermaket high energy coil ,you also need to replace the stock spark plug cables with performance types such as silicon cables that can within stand high KV passing through without overheating. In turns you have to set the plug gap much wider than the std setting so as to allow the high KV to perform a better sparking. does changing stock coil and cables does it help in Fc? i thought the stock is always the best Link to post Share on other sites More sharing options...
Esky Neutral Newbie December 24, 2004 Share December 24, 2004 Stock is best... for cost-cutting, maximised profit and general use! Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 24, 2004 Share December 24, 2004 More power = more fuel. Piece meal modifications can cause more headache. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 24, 2004 Share December 24, 2004 I am with you Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 29, 2004 Share December 29, 2004 i thought the stock is always the best it depends on the make of the car, to what I know Alfa stock plug cables are actually racing plug cables from Bosch Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 29, 2004 Share December 29, 2004 All sifu out there. Do anyone know what is the correct Splitfire Triple Platinum spark plug gap width for Altis 1.6. Thanking in advance..... FYI I didnt buy from the distributor (Autodesign), asked a friend to buy from USA. Cheaper but dont know the original gap width is correct or not. your Altis stock gap size should be 1.1mm Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 29, 2004 Share December 29, 2004 Gap setting depends on the coil or ignitor's kilovolt output. The std output is about 25kv and by the time it reaches the plug( due to spark plug cable resistance) the high voltage available maybe about 18kv. If you replace the OEM stock coil with aftermaket high energy coil ,you also need to replace the stock spark plug cables with performance types such as silicon cables that can within stand high KV passing through without overheating. In turns you have to set the plug gap much wider than the std setting so as to allow the high KV to perform a better sparking. well, agree on this but most jap cars are now using coil over plugs, so the lost is much more lesser than the previous design of iginition pack with plug cables Link to post Share on other sites More sharing options...
Ah_veo Neutral Newbie December 29, 2004 Share December 29, 2004 (edited) so as long as the gap size is right.....any plugs oso can use??? btw, mine is 1.5L Aveo. gap size is 0.7-0.8. can last 10-20k.... what do u suggest,bro? Edited December 29, 2004 by Ah_veo Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 30, 2004 Share December 30, 2004 Yes you are correct, coil-on-plug will cut out the Kv loss due to wire resistsance. Link to post Share on other sites More sharing options...
Genie47 1st Gear December 30, 2004 Share December 30, 2004 Got to consider heat range as well. Wrong heat range and you will encounter difficulty. Link to post Share on other sites More sharing options...
Fuzzylogic 2nd Gear December 30, 2004 Share December 30, 2004 I was wondering if you use one of those thick grounding wires to replace the stock 12v rail to the distributor on coil, will there be any benefits? I know it might not be feasible but juz curious. ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Old WW2 Relic disposals
Is this Altis bodykits optional??
All new Altis 2014
All new Altis 2014
Steering rack noise on 2010 Altis
Wheel Bearing Labour cost
Plug-and-play vaccine
