Aikshin Neutral Newbie October 17, 2004 Share October 17, 2004 hi all, wonder are there any one out there using swirl mark removers prior to application of klasse aio and then klasse sg ? found the car got lots of fine scratches on my black car, (tough to maintain black) so wonder if i use the swirl mark removers prior to the klasse aio, wun the aio remove the swirl mark removers since aio is a cleaner ? any recommended swirl mark removers ? seems 3m swirl mark removers is very popular cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Chuabc Neutral Newbie October 18, 2004 Share October 18, 2004 If u get the filler type SMR then AIO will tends to remove it. BUt if u get the non-filler type SMR, AIO will not be a problem cos the SMR really minimize the swirl. Link to post Share on other sites More sharing options...
Marcostan 4th Gear October 18, 2004 Share October 18, 2004 Aiksin, I suggest the first polish u go 4 professional to do it. They know and well remove all the swirl marks. After that u can DIY and it shall be more easy to maintance. For the shop using Klasse product u can find their advertisement in this month's WHEELS magazine. Let them do the first polish to your Babe. Good Luck, MarcosTan Toyota Rav4 Link to post Share on other sites More sharing options...
Aikshin Neutral Newbie October 18, 2004 Author Share October 18, 2004 do you know which are the non-filler type of SMR ? cheers Link to post Share on other sites More sharing options...
Leonknapp Clutched October 18, 2004 Share October 18, 2004 If no filler means must be abrasive. not recommended unless ur a pro and u should have a machine buffer. If using hand fillers is the only solution. Cheers! ↡ Advertisement Link to post Share on other sites More sharing options...
Encounters with tyre shop
Good ENT specialist to recommend ?
