Othello Supersonic December 3, 2017 Share December 3, 2017 On 12/2/2017 at 2:34 PM, littlelight said: Last year went to another workshop when I felt the vibration. Workshop only casually mentioned that could be due to engine mounting. But back then I asked if I should change it the guy told me not needed unless vibration becomes worse. This time round I went autobacs and was advised to change it. Anyway reason for me not going back to the same workshop cause the guy that I trust no longer works there and has already went back Malaysia. ahhhh, autobacs ...... Never trust those slimeballs from there or Spark and similar setups. If you are not aware, their service advisors do get some sort of commission for work done Unless the rubber has disintegrated (unlikely), one can live with worn mountings for a year. Less than a year, its really up to you. For eg. Taxis. You think their maintenance regime really follow guidelines ? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 3, 2017 Share December 3, 2017 My previous 5er one set 4pcs of mounts cost $120. Who say all Beemer parts ex. Link to post Share on other sites More sharing options...
Alphas 2nd Gear December 5, 2017 Share December 5, 2017 On 12/3/2017 at 12:08 AM, littlelight said: Thanks bro. Anyway any idea if I do not change will there be any safety issue?Change my 4x engine mounts on 11th yr 150k. If you don’t change it, the vibration will get stronger but should not cause catastrophic failure. Another way is to check the rubber on the all mounts and physically see which one or two are really worn out. Sometimes it is alright just to change one or two since the other mounts are still ok. Since you are scraping soon and if you tahan the vibrations then live with it. 1 Link to post Share on other sites More sharing options...
Yewheng Twincharged December 5, 2017 Share December 5, 2017 (edited) On 12/3/2017 at 12:08 AM, littlelight said: Thanks bro. Anyway any idea if I do not change will there be any safety issue?Bad engine mount can cause stress to other components. [url[/url] Take a look at the above YouTube link on bad engine mount, and see how the engine move up and down. These movement can cause stress to other components, beside that if the mount is bad enough, you may even feel that the car has no power. https://www.yourmechanic.com/services/engine-mount-replacement Saving small money and end up expensive repair. That is the risk you may want to consider. 1yr more to scrape probely can get through it, but just don't drive with damaged engine mount for too long. Edited December 5, 2017 by Yewheng Link to post Share on other sites More sharing options...
Yewheng Twincharged December 5, 2017 Share December 5, 2017 On 12/3/2017 at 7:31 AM, Othello said: ahhhh, autobacs ...... Never trust those slimeballs from there or Spark and similar setups. If you are not aware, their service advisors do get some sort of commission for work done Unless the rubber has disintegrated (unlikely), one can live with worn mountings for a year. Less than a year, its really up to you. For eg. Taxis. You think their maintenance regime really follow guidelines ? Ya but then taxi lifespan only 7yrs. So if don't change engine mount it's okay. Imagine engine mount never change for more then 10yrs and with taxi mileage. Surely can feel the big difference. Link to post Share on other sites More sharing options...
littlelight Neutral Newbie December 6, 2017 Share December 6, 2017 On 12/5/2017 at 9:58 AM, Yewheng said: Bad engine mount can cause stress to other components. [url[/url] Take a look at the above YouTube link on bad engine mount, and see how the engine move up and down. These movement can cause stress to other components, beside that if the mount is bad enough, you may even feel that the car has no power. https://www.yourmechanic.com/services/engine-mount-replacement Screenshot_20171205-181149.png Saving small money and end up expensive repair. That is the risk you may want to consider. 1yr more to scrape probely can get through it, but just don't drive with damaged engine mount for too long. Thanks for the advice! Anyway does anyone know of any workshop that does engine mount repair? I just brought my car to another workshop and was quoted 700 plus for engine mounts. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged December 6, 2017 Share December 6, 2017 On 12/3/2017 at 7:02 AM, littlelight said: Ok thanks thanks! Asked this cause I remembered the mechanic was mentioning about safety hazard if never change. Yes. Axle or what may fail prematurely if the mounts are damaged. Since you are scraping, you can consider to change just those damaged ones and not the whole set. I changed mine around 600 for a set of 3. Most workshop can do that. Since it is a half to full day job, you might want to find one near your home or workplace. Link to post Share on other sites More sharing options...
Acewin 4th Gear December 6, 2017 Share December 6, 2017 On 12/6/2017 at 7:23 AM, Stratovarius said: Yes. Axle or what may fail prematurely if the mounts are damaged. Since you are scraping, you can consider to change just those damaged ones and not the whole set. I changed mine around 600 for a set of 3. Most workshop can do that. Since it is a half to full day job, you might want to find one near your home or workplace. Hi, Just to share, my WS use a jack to slightly jack up the engine and change the mounting one by one without take out engine. Whole process done in about an hour. After that car smooth swee swee and quiet like new. Link to post Share on other sites More sharing options...
Yewheng Twincharged December 6, 2017 Share December 6, 2017 On 12/6/2017 at 7:09 AM, littlelight said: Thanks for the advice! Anyway does anyone know of any workshop that does engine mount repair? I just brought my car to another workshop and was quoted 700 plus for engine mounts. Actually no need change La, if really that bad and end up other parts spoil than scrap car lor. Link to post Share on other sites More sharing options...
xmake Clutched May 28, 2018 Share May 28, 2018 Hi all, Hope to get some advise here. Was told by AD to consider changing my engine mount. The vibrations and sound is very obvious. Unless I don't mind, can still continue to drive. No risk impact. Price to change around $600+ Appreciate your feedback Thanks Xmake 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 28, 2018 Share May 28, 2018 On 5/28/2018 at 10:07 AM, xmake said: Hi all, Hope to get some advise here. Was told by AD to consider changing my engine mount. The vibrations and sound is very obvious. Unless I don't mind, can still continue to drive. No risk impact. Price to change around $600+ Appreciate your feedback Thanks Xmake your car left how long more? if it has 2 or more years. i suggest just change it. 600+ still ok la. divide by the number of days not costing you much also. you will surely cannot tahan the vibration. Link to post Share on other sites More sharing options...
xmake Clutched May 28, 2018 Share May 28, 2018 On 5/28/2018 at 12:22 PM, StreamRSZ said: your car left how long more? if it has 2 or more years. i suggest just change it. 600+ still ok la. divide by the number of days not costing you much also. you will surely cannot tahan the vibration.Hi StreamRSZ,Still got another ten years. Cause just renewed COE. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 29, 2018 Share May 29, 2018 On 5/28/2018 at 3:09 PM, xmake said: Hi StreamRSZ, Still got another ten years. Cause just renewed COE. Link to post Share on other sites More sharing options...
song77 2nd Gear May 29, 2018 Share May 29, 2018 How do we know if the mounting and bushes are worn out? Any symptoms? 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 29, 2018 Share May 29, 2018 On 5/29/2018 at 11:33 AM, song77 said: How do we know if the mounting and bushes are worn out? Any symptoms? vibrations will be the symptoms noticed.may also experience engine lack of power if the mounts are badly damaged. will have noticeable sound too. Link to post Share on other sites More sharing options...
song77 2nd Gear May 29, 2018 Share May 29, 2018 On 5/29/2018 at 12:06 PM, StreamRSZ said: vibrations will be the symptoms noticed.may also experience engine lack of power if the mounts are badly damaged. will have noticeable sound too. Ok. Noted. Thank you. What kind of sounds? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 29, 2018 Share May 29, 2018 On 5/29/2018 at 1:02 PM, song77 said: Ok. Noted. Thank you. What kind of sounds? vibration sound. metal knocking sound. Link to post Share on other sites More sharing options...
xmake Clutched May 31, 2018 Share May 31, 2018 On 5/29/2018 at 1:02 PM, song77 said: Ok. Noted. Thank you. What kind of sounds? The vibration and vibe sound in the front of your car will be very obvious especially during stationary. Imagine your phone vibrates but much much louder and stronger. But don't worry, the engine won't drop yet. My AD say so. ↡ Advertisement Link to post Share on other sites More sharing options...
Teana repair/parts
Teana repair/parts
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
