Beyond_26 Neutral Newbie October 16, 2004 Share October 16, 2004 how much u get ur car for? ↡ Advertisement Link to post Share on other sites More sharing options...
Bleuzone 1st Gear October 16, 2004 Author Share October 16, 2004 Thanks. I think I will drop by there too. My rubber quite old already..... Some borken somemore! Link to post Share on other sites More sharing options...
Bleuzone 1st Gear October 16, 2004 Author Share October 16, 2004 Erm..... I got it at $36K early this year. Now worth 10K less... Link to post Share on other sites More sharing options...
D15z7 Neutral Newbie October 17, 2004 Share October 17, 2004 (edited) if you need any brand-new original Honda parts.. can try the following stockist below.. much cheaper than getting from elsewhere.. can bring to my workshop in AMK.. they'll charge you for labour only.. - Min Ghee Motors - Tanly Motors - Thian Sing - Koon Sing btw do you need any peformance parts? i have some to let go: - Super Dynamics free-flow exhaust muffler with 2" pipe (stock look, 6 mths) - Vision front strut bar (Original Made in Japan) - Cusco lower arm bar - Honda 1.1 bar radiator cap - Honda SOHC spark plug cables (6 mths) - Denso Iridium IK20 (used 2000km only) Edited October 17, 2004 by D15z7 Link to post Share on other sites More sharing options...
Beyond_26 Neutral Newbie October 17, 2004 Share October 17, 2004 yes, now only 26k, but at interest of 3.95 Link to post Share on other sites More sharing options...
Konspire Neutral Newbie October 18, 2004 Share October 18, 2004 in fact got a problem wif my brake pad...it's seems loose and always gives a knocking sound. my mech did it few times n they so shitty that I felt like I am always wasting my time by coming down to fix the same problem. Link to post Share on other sites More sharing options...
Konspire Neutral Newbie October 18, 2004 Share October 18, 2004 it wld be helpful if u could give exact address...thxs... Link to post Share on other sites More sharing options...
Bleuzone 1st Gear October 18, 2004 Author Share October 18, 2004 Hi hi, can I enquire more abt the lower arm bar? Is it for the front or rear? And how does it help for the car? Thx! Link to post Share on other sites More sharing options...
Civic92 Neutral Newbie October 18, 2004 Share October 18, 2004 Perfect Auto Centre Company Blk 20, Woodlands link, #01-21, Woodlands East Industrial Estate Tel: 6755 6358 I am also one of the customer by chance, just feel that their stuff are reasonable. Link to post Share on other sites More sharing options...
Konspire Neutral Newbie October 18, 2004 Share October 18, 2004 r they somekind of honda agent? i guess they do not install huh? Link to post Share on other sites More sharing options...
Civic92 Neutral Newbie October 18, 2004 Share October 18, 2004 I don't know whether do they do installation, but i am sure they will direct you to their associates. Link to post Share on other sites More sharing options...
D15z7 Neutral Newbie October 18, 2004 Share October 18, 2004 Authorised Honda Stockist: Tanly Motor Pte Ltd Address: Blk 261, Waterloo Street, #01-03/04/05 Tel: 6336-2600 Thian Seng Motors Pte Ltd Address: Blk 261, Waterloo Auto Centre, Waterloo Street, #01-22/02-24 Tel: 6337-1795, 6336-9777 http://www.autoparts.com.sg/thianseng/ Min Ghee Auto Pte Ltd 8, Jalan Lembah Kallang, #01-01, Min Ghee Building Tel: 6298-9549 http://www.wcbn.com.sg/minghee/ Koon Sing Enterprise 40, Dunlop Street (opp. Sim Lim Tower) Tel: 6294-1243 Link to post Share on other sites More sharing options...
D15z7 Neutral Newbie October 18, 2004 Share October 18, 2004 in fact got a problem wif my brake pad...it's seems loose and always gives a knocking sound. my mech did it few times n they so shitty that I felt like I am always wasting my time by coming down to fix the same problem. bro seems like your mechanic did not do a good job for your brakes.. some likely causes: - brake bleeding not done properly - brake pad not installed properly - rotors warped (need replacement or skimming) - brake caliper/piston faulty (need brake overhaul kit) drop-by my workshop & ask the boss Swee Fong to do a thorough brake check for you.. Link to post Share on other sites More sharing options...
D15z7 Neutral Newbie October 18, 2004 Share October 18, 2004 (edited) Hi hi, can I enquire more abt the lower arm bar? Is it for the front or rear? And how does it help for the car? Thx! CUSCO Lower Bar, Type I, Front It's like a front lower strut bar to stiffen your front chasis.. improves cornering performance and increases vehicle stability.. The Type I lower arm bar is made of tubular aluminum to help reduce weight over the stock bracing without compromising strength. It is a 2-point setup and includes all the required hardware for installation. It bolts on easily using normal hand tools. Edited October 18, 2004 by D15z7 Link to post Share on other sites More sharing options...
Konspire Neutral Newbie October 19, 2004 Share October 19, 2004 thxs for the advice,m ate. I'll drop by to see him, is he always bz? is he packed on saturdays? wat is his opening hours? anyways, i am looking for a place where i can redo my spare tyre cover in the boot, any idea? like to get a more flatter one cause present one is bulging and can't really put much things........thxs for ur infos... Link to post Share on other sites More sharing options...
D15z7 Neutral Newbie October 19, 2004 Share October 19, 2004 He's usually busy on Saturdays.. so it'll be a good idea to drop-by early in the morning like 9am before the crowd comes in.. Spare tyre cover can be done at most audio shop.. just like doing up a rear speaker board they'll use a piece of thick plywood and cut according to whatever profile.. don't know how much it'll cost though.. Link to post Share on other sites More sharing options...
Bleuzone 1st Gear October 19, 2004 Author Share October 19, 2004 Hmm... In that case then I dun think I need it. I already have 1 that runs across my engine. Maybe I'll get 1 for my rear next.... Thx! Btw, I think I shd be dropping by the mech today. Either the one you recommand or another one creative_tec recommanded. Await my field report..... Link to post Share on other sites More sharing options...
Konspire Neutral Newbie October 20, 2004 Share October 20, 2004 yeah...tell us how it went.... ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
2022 Toyota GR Corolla
2025 Mitsuoka M55
2025 Mitsuoka M55
Honda Civic servicing... Which workshop to go?
